Spark but no fire.
- Capt806dfd
- Thank you received: 2098
Whether using points, igniter pulse coils, or Dyna modules, each type has a left-hand (nine o'clock) component and a matching right-hand (three o'clock) component.
Wiring from the coils to the components is basically the same.
Left component goes to whichever coil is connected to the outside sparkplugs #1/4.
Right component goes to whichever coil is connected to the inside sparkplugs #2/3.
When correctly installed on a points system, the left contacts will open just as the 1/4 F mark aligns with the permanent case mark.
On a Dyna-S system, the magnet embedded in the rotor will pass the left module just as the 1/4 F mark aligns with the permanent case mark.
On Kaw's oem igniter system, the rotor projection will pass the left module just as the 1/4 F mark aligns with the permanent case mark.
- Capt806dfd
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Fuel mixture may not be getting into combustion chamber (for whatever reason).
What happens if spray starter fluid into carb intakes while trying to start the engine?
Combustion requires only three elements:
Adequate compression;
Sufficient properly timed spark;
Correct air/fuel mixture.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Are spark plugs damp with gasoline?
As usual, this guy is no help at all! :laugh: :laugh: :laugh:
:blush: Sorry Patton, dont mean to bust yer balls.
Keep up the great info.
As noted in previous diagrams, you could just have the plug wires backwards. Try it... switch 4-3 and 1-2 and kick it a few times. Worst it can do is afterfire.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
Remember, cold cylinders need lots o' fuel to get going so always engage the choke. If its a variable type choke, try changing it to different positions.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Please Help!!! I finaly have my KZ 650 rebuilt and everything put back together but it wont start. I have a good spark, fuel flowing to the carbs but I kick and I kick but it will not fire off, any ideas?
Be sure and not touch throttle grip when starting cold engine with choke fully ON.
The enrichener circuit is designed to function when the throttle slides are closed fully down. That means left in idle position.
Do NOT "crack" the throttle.
Do NOT "pump" the throttle.
Just leave the throttle alone.
...What happens if spray starter fluid into carb intakes while trying to start the engine?....
TeK9iNe wrote:
... switch 4-3 and 1-2 and kick it a few times. Worst it can do is afterfire....
Pop Quiz ---
Which resulted from using stater fluid?
Which resulted from the dreaded afterfire?
[Click on image to feel the heat.]
- Kitten Tooth
- Thank you received: 10
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- BSKZ650
- Thank you received: 14
Does the starter not work? or is the batter ytoo low to use the starter? you need a fully charged battery to get a good hot spark.
last thing, have you checked compression?
77 ltd1000, current rider
76 kz900, just waiting
