Coughing, Sputtering, Hesitation. My mystery!
- newbikekiller
The entire bike is stock (incl. jetting) except for a 4-1 kerker setup. I haven't opened up the carbs, so I can't be for sure that all of that is stock. The bike has just recently been tuned up. And was running great for 150 miles or so.
This bike has absolutely no other running problems as far as I can tell, starts right up, idles nicely, and after 6.5K picks up the speed with no/little hesitation.
Here are my theories, feel free to tell me if I'm headed in the right/wrong direction or if there is any other suggestions.
1.) Exhaust needs packing (maybe pipe resonates at this RPM range or something)
2.) Low power to coil(s)
3.) Bad coil(s)
I've ruled out fuel delivery as the potential cause.
- steell
(4) Bad plug wires
(5) bad plug caps
Those two can be measured for resistance with a multimeter.
- newbikekiller
I replaced the plug wires and caps when I got the bike 3 months ago....
So pretty much everyone is thinking ignition troubles?
- OKC_Kent
- Thank you received: 20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- OKC_Kent
I thought when a pipe is added you increase the main jet a size or two. Does it pull to redline from the stumbling point? What do the plugs look like?
ok, you said it pulls to redline, I missed that. Maybe the clips on the needle need to be checked.
Oklahoma City, OK
- newbikekiller
Plugs are pretty much white, but I haven't done a real plug chop yet so I dunno whats really going on. WG told me that with a 4-1, there isn't much need to rejet unless I feel stumbling 7-9K full throttle, which I don't. I might upp the main one for good measure anyway.
Packing the exhaust did help a bit, but because of its fairly sudden appearance, I'm betting its gonna end up being a coil (low power or bad coil). I also had a weird problem where the No. 2 cylinder wouldn't fire on choke, presumably because it didn't have enough power to fire with the A/F ratio low. I don't know if the bike still does that, because its warm enough not to need any choke here in michigan.
I'll let ya'll know as soon as I know.
- kawsakiman
- Thank you received: 6
- 77KZ650
- Thank you received: 7
Do a plug chop and see if they are still white, if so, it may be beacause of less packing (less restrictive)Plugs are pretty much white, but I haven't done a real plug chop yet so I dunno whats really going on.
07 MDP Rookie of the Year
- Tazzmann
- newbikekiller
Thanks for the help.
- Snakebyte
Got enough fuel flow?
I've got an open pipe and mine runs fine.(just a cover to fool patrol men)
Post edited by: Snakebyte, at: 2006/04/11 14:38
- newbikekiller
1.) Swapped coils
2.) Swapped advancer unit
3.) Powered up coils w/ WG's trick
4.) Packed exhaust
5.) Got rid of inline fuel filter (want a clear one anyway)
It seems that the bike isn't revving as hard as it could on the top end, but its hard for me to tell because my tachometer is pretty much all over the place under hard acceleration.
There is sometimes a slight stutter before 4K at WOT, and there is also a noticable stutter when travelling at high speeds between 5-6.5K (approx from tach) accellerating between 1/2-Full throttle.
Here is my summation
1.) Ruled out any low-power ignition issue [Thanks kawasakiman]
2.) Ruled out any fuel flow issue
2.) Still need to dynamically check timing (and adjust) [Thanks Tazzman]
3.) Check intake boots [thanks Snakebyte]
4.) Need to get adjustable needle jet and main jets 1+2 sizes larger. Clean carbs, set fuel level, install 1 size larger main jet and do a plug chop under 1/2 throttle and full throttle conditions. [Thanks 77KZ650]
