White smoke after warm up.
- Jim65
24 Oct 2005 08:55
I'll probably do the top end this winter anyway, but I was wondering if anyone could diagnose the problem. I have an '81KZ750E with about 28,000 mi. The bike, just recently, started blowing some stinky white smoke from the exhaust, but only after a complete warm up. The onset of the problem came on quite rapidly. I have'nt performed any diagnostics such as compression, however two of the cylinders look like they are running rich, as determined by looking at the plugs. Thanks
- Spock
Re: White smoke after warm up.
24 Oct 2005 10:53
I would first suspect Valve Stem Guides.
Spock
Spock
- steell
24 Oct 2005 11:04
Oil smoke is rather stinky, but gas smoke (due to rich mixture) will make your eyes burn.
So, which is it?
So, which is it?
- Jim65
- craigpuckett
24 Oct 2005 15:57
If the 2 cylinders that are fouling plugs are 2&3 I would suspect the O ring around the camchain galley/head gasket.I have an 81' J motor that has developed an oil leak out of the front of the motor and thats what I suspect on it.
just my .02:)
just my .02:)
