gear selector play
- asevans
11 Jul 2010 18:32 - 11 Jul 2010 18:47 #381778
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
gear selector play was created by asevans
was out riding around checking on my plug issue and all of a sudden i couldnt down shift. got home and noticed alot of play on my gear selector lever. well exactly 2 inches of play center to center at the farthest point out on the lever. took the cover off and well i dont know what to do now. what happened?
1978 Z1-R Project
Last edit: 11 Jul 2010 18:47 by asevans.
- hocbj23
- Visitor
11 Jul 2010 18:39 #381779
by hocbj23
Replied by hocbj23 on topic clutch lever play
this is a KZ 900?When u took cover off was wire from clutch attached to the actuator arm or was it just dangling loose in the housing?
- asevans
11 Jul 2010 18:46 #381781
by asevans
1978 Z1-R Project
Replied by asevans on topic clutch lever play
im sorry i said clutch lever i meant gear selector ill edit. yes the kz900
1978 Z1-R Project
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 Jul 2010 19:30 #381804
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic gear selector play
The selector sprin can be eiher worn/broken/poped out of place somehow.
Take all that linkage apart and clean and lubricate all of it, then reassemble. You'll find it makes a world of difference.
Also, the cover can be slightly off causing the shifter shaft to stick at either end of travel.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
