- Thank you received: 5
Wrapping exhaust headers
- ELCouz
11 Jul 2010 18:22 - 11 Jul 2010 18:28 #381776
by ELCouz
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Wrapping exhaust headers was created by ELCouz
Hi,
Just want to know if wrapping the exhaust headers will upset the carburetor adjustment (running leaner ??) since they will be running hotter than before?
I'm trying to move the most of the heat away from my engine since i'm afraid of my stock oil cooler is to close from the aftermarket hindle 4 into 1 exhaust.
Abnormal heat (110F) here and traffic don't mix well.
Bike: KZ750-R1 GPZ '82
regards,
laurent
regards,
laurent
Last edit: 11 Jul 2010 18:28 by ELCouz.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
11 Jul 2010 19:27 #381802
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Wrapping exhaust headers
With the pipe wrap you're jetting will be fine.
The wrap will start to look pretty dirty after a season or so.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
- Thank you received: 337
11 Jul 2010 23:05 - 11 Jul 2010 23:06 #381891
by bountyhunter
Replied by bountyhunter on topic Wrapping exhaust headers
From what I read it generally ruins the exhaust pipes in short order. Jetting effect should be small. Hot gas is lighter so it theoretically makes the exhaust flow better.
Last edit: 11 Jul 2010 23:06 by bountyhunter.
