valve adjustment and chain sprocket
- stonemaster
11 Jul 2010 00:28 - 11 Jul 2010 02:11
73 Z1 900 FSM give between 38 and 52 in lbs for bolts on timing chain guide sprocket , how does the difference in this scale affect the valve clearance, or does it at all, in other words, if I have it on 50 and back down to 40 or 45 will that change the clearance between lobe and shim ???
this is why i'm asking, after putting head back on bike i checked the valve clearances, 6 of the 8 had NONE, this is the first check since purchasing a couple of months ago. I did not check before removing head ( I wish i had) have ticking in #4 exhaust valve that i didnt have before, (removed head to repair bad header studs) everything reassembled correctly, replace in exactly same locations(bolt,bearings , buckets etc ..) Any ideas ??/
Last edit: 11 Jul 2010 02:11 by stonemaster.
- trianglelaguna
Re: vlave adjustment and chain tensioner
11 Jul 2010 00:56 - 11 Jul 2010 02:51
you changed the question so i changed my answer,,,,:ohmy:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
Last edit: 11 Jul 2010 02:51 by trianglelaguna.
- Mcdroid
- Gone Kwackers
Re: valve adjustment and chain sprocket
11 Jul 2010 06:09
Your cam tower sprocket has nothing to do with the clearances between your cam lobes and valve shims. You need to double check the torque values for the cam caps (carefully, as the head will strip if cam bolts are too tight)...then you need to re-shim.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- stonemaster
- bountyhunter
11 Jul 2010 12:11
Do not go over 100 inch-pounds (about 8 ft-lbs)on the caps and make sure you have a low range torque wrench which is accurate there.
