Weird noise after rebuild
- kawasakibikefan
- Riding is a passion most do not understand.
'75 Z1B
'95 KLR250
My Future Buying List:
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Dustproof
I am going to pull the tappet cover and have a look at what is happening with the engine running, it could be an oil supply thing because mine started doing this when I replaced the sump after repairing the Starter clutch.
Noel
- Old Man Rock
- Thank you received: 225
If out, re-torque all your engine to frame bolts as well...
As in my case, found several of them loose after 50 mile break in time frame.... Hell, the back long bolt was just sitting there 3/4 in where the nut back spun and was gone... :S
Ran this by Plum & Larry and they both replied the same, this is common and expected...
Garden hose or stethoscope around the engine case while idling...
Just a thought....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Dustproof
Noel
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Could just be a slightly large gap on one of the shim/valve clearances.
I say, ride the sucker. :laugh:
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- kawasakibikefan
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Old Man Rock
A stehoscope would be a good $5 investment... HB Tools...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kawasakibikefan
One issue came to mind on another members similar rebuild last year... Turned out it was one of the top idler mounting screws vibrating on the valve cover....
Would the old screwdriver method also work here?
'75 Z1B
'95 KLR250
-Kawasaki KLX450R
-Yamaha R1
-Suzuki DR-Z400SM
- Old Man Rock
Stethoscope is truly amazing on the volume/amplitude in sound pickup.... plus with the extensions you can get down in those tight little places other methods wouldn't...
Example... On my new build last summer, I had a squishing sound (avi clip provided to mentors) on WTF was it... Stumped everyone... Only occurred when running really hot (AZ heat in summer and due to dyo oil/no cooler)...
Plumm turned me onto the Stethoscope idea...
The sound seemed to be coming up top but with the scope, traced it all the way down to the oil pump! :S Even though the oil pressure was in spec the pump had a squishing sound... Was weird...
Anyhoot, e-bay, $20 pump no more sound... Life was good once again.... :laugh:
Either method would work... I think Plumm just uses the meatl in his head... Lays his head on the valve cover and the vibration oscillates & transfers into his ear canal.
Or was that his willy :blink: he was using, I forget now...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- OKC_Kent
- Thank you received: 20
My 900 rings like that and it is my front brake lever. I put my pinkie finger on it and it quits. I am scared I will break the bolt if I tighten it any more so I pinkie ride when it bothers me.
Happened on my 650 too. Also the gas cap lock tumbler will vibrate and make a similar noise.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
