- Thank you received: 5
Oil dripping from carburettor
- ELCouz
I have a GPZ750 1982 (KZ750-R1). Every time i stop the bike and put it on it's side stand. I have drips from the Carb #1 off engine oil (dripping from the lowest part of the carb.... the drain plug). Drip eventually stop after few drops put always leave an oil spot on the tarmac.
What in hell could this oil come from?
Best regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- lordbarclay
Are running a stock air box?
The only path for oil to the carb is the crank vent system.
Is the air box oily?
Have you checked the oil level to make you are not over filled.
If all of those question are negative,are you sure that it's oil and not gas?
R.
Living on the wrong of the bell curve!
KZ900A4
KZ650C3
RD250(don't hate me)
- TerryK
- Thank you received: 3
Is it coming from the crank vent?
R.
All good things to check. Also check to see if the valve cover gasket is leaking at the back. Oil may be running down the engine to the carb boot then on to the carb.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- ELCouz
There's some oil sludge around the breather tube (connected to the vent)
Yes everything is stock except the pipe.
yes i've cleaned it.
I'm 1/16 over the glass sight but somebody say in this forum if you are a little bit over its no big deal.
Everything is clean around the valve cover gasket...
Is there a filter inside the crankcase breather compartment (bulge with the screw)?
Have a nice day!
Laurent
- Thank you received: 2829
- TeK9iNe
- What did you do!?!
Oil should be at half the height of the glass, not over/@ the top, that IS too much, and can blow out of the breather.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
All goo info so far... follow the oil trail.
GL.
yep!!
- ELCouz
GL.
you are right... I've removed nearly a pint of oil to make the oil level between the 2 marks.
EDIT: it is very hard to check the level while keeping the 500 pounds bike centered on its wheel :S ... previous owner broke the center stand frame attachment.
Now no more oil leaks.
Can somebody explain me how does it work. I mean how so little amount overfill can make the oil spit from the breather and increase the overall oil pressure?
Best regards,
laurent
- Thank you received: 2098
...is very hard to check the level while keeping the 500 pounds bike centered on its wheel :S ... previous owner broke the center stand frame attachment....
Click here > For The Easy Way
- ELCouz
regards,
laurent
