1979 kz1000 st shaft drive. leaking at shaft
- MaxxRonin
09 Jul 2010 10:34 #381266
by MaxxRonin
1979 kz1000 st shaft drive. leaking at shaft was created by MaxxRonin
I purchased the kz yesterday. The guy that I bought her from said that he had her running last year a couple of times without a problem. Today when I went to start her up, third kick, she came to life. What an excellent sign i thought. I only kicked her over because the starter is dead/mis-wired). As i was about to pull out of the garage my buddy made me stop. Oil was pouring out at what appeared to be the junction of the shaft drive and the trans. I ran it for about 5 minutes before I had to shut her down so she wasn't leaking instantly. but can that seal go without notice? the leak was at the bottom of the junction which is in the center of the photo. For reference, the bottom center of the photo is right above the front left footpeg.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
09 Jul 2010 12:32 - 09 Jul 2010 12:39 #381280
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 1979 kz1000 st shaft drive. leaking at shaft
You mean these parts:
Check the connecting components for cracks/wear, and make sure the clamp is nice and tight.
If its just the seal behind the plat, that can be easily repaired with a liquid rtv sealant.
GL.
Parts list:
1 SCREW-PAN-CROS
2 SPRING,LEAF
3 SHAFT ASSY,PROPELLER
4 COUPLING,PROPELLER SF
5 CIRCLIP, 20MM
6 PIN-DOWEL,4X6
7 "0" RING,20.5MM
8 SPRING,PROPELLER SHAF
9 BOOT
10 NUT,10MM
11 CLAMP,BOOT FITTING
GL.
Parts list:
1 SCREW-PAN-CROS
2 SPRING,LEAF
5 CIRCLIP, 20MM
6 PIN-DOWEL,4X6
7 "0" RING,20.5MM
9 BOOT
10 NUT,10MM
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 09 Jul 2010 12:39 by TeK9iNe.
- MaxxRonin
09 Jul 2010 17:48 #381357
by MaxxRonin
Replied by MaxxRonin on topic 1979 kz1000 st shaft drive. leaking at shaft
Most excellent. Wanted to make sure i was right with seal before i started picking up parts. one other question, since im still waiting on my clymers manual,the seal between trans and shaft obviously seems to be one solid tube, are trans oil and shaft oil the same? why would there be two different holes for filling then?
- TeK9iNe
09 Jul 2010 18:13 #381361
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
The shaft-train oil is seperate from the trans/engine oil.
Pretty sure its 90W SAE Gear Oil for the Shaft-train, and a good 10W40 or better for your engine oil.
Use a wet-clutch approved motorcycle oil!
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
