- Thank you received: 10
Clutch not engaging no matter where its adjusted
- Kitten Tooth
08 Jul 2010 16:29 #381142
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Clutch not engaging no matter where its adjusted was created by Kitten Tooth
i just got my 81' KZ1000LTD running pretty good yesterday. i adjusted the clutch in accordance with the manual. I have the bike on the center stand right now and the front tire is flat so the back wheel doesn't touch the ground. I figured i would put it in gear once to see if the back wheel spinned. I shifted into 1st with the clutch pulled in and i looked back at the back wheel. I hadn't let the clutch out yet and the back wheel was spinning. So i shut the bike off. I have adjust the the metal adjuster on the mid section of the cable. No matter where i set it, the clutch doesn't seem to pull it out of gear like it should. I pull it in and try to turn the wheel in 1st gear and it barely spins. When i let the clutch out it won't spin at all. So, the clutch just barely works. I recently drained the oil to fix the starter clutch and the crank case was empty for a week or so. Do you guys thik that maybe the clutch friction plates are stuck together? My GS300L did the same thing when i drained the oil but it worked itself out of it.
WHATS WRONG WITH MY BIKE!!!??
Thanks guys,
KT
Thanks guys,
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- hocbj23
- Visitor
08 Jul 2010 17:45 #381155
by hocbj23
Replied by hocbj23 on topic Clutch not engaging no matter where its adjusted
U said u adjusted the clutch by the manual.Did u just adjust the cable or did u adjust the clutch release via the small sideplate as well?
- hocbj23
- Visitor
08 Jul 2010 17:49 #381156
by hocbj23
By the way, I like my clutch to "drag" just a bit,so when my bike is up on the paddock lift and in first with the clutch in, the rear wheel spins as well.when its on the ground,the bike "creeps" just a bit in 1st.I set it that way on purpose.bj
- Kitten Tooth
08 Jul 2010 17:58 #381158
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Clutch not engaging no matter where its adjusted
My dad adjusted the screw with the locknut on the worm gear for the clutch pushrod. It was under that cover with the two allen-key bolts on the pushrod cover. We adjusted that and the bolt adjuster on the cable. I think that the plates are stuck together from sitting with no oil. Im not certain though..
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- steell
08 Jul 2010 18:02 #381160
by steell
Replied by steell on topic Clutch not engaging no matter where its adjusted
That's normal, oil drag alone will keep the rear tire spinning when it's off the ground like that.
- JR
- Thank you received: 448
08 Jul 2010 18:02 #381161
by JR
Replied by JR on topic Clutch not engaging no matter where its adjusted
I dont think there is anything wrong with your bike. I think that's normal. Dont do anything until a few others have posted a response.
- Kitten Tooth
08 Jul 2010 18:16 #381166
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
kk, i get a new front tire on friday. The one thats on there is cracked really bad. When i get my tire tomorrow, i should have my lights wired, foot pegs brake stays all back on after cleaning, and my new 6 pin connectors on in the head light bucket. I'll just leave it for now. From what you guys say, this thing doesn't sound too catastrophic:) Thanks for all the replies,
KT
KT
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- TerryK
- Thank you received: 3
10 Jul 2010 07:13 #381458
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Clutch not engaging no matter where its adjusted
Normal.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- otakar
10 Jul 2010 07:21 - 10 Jul 2010 07:25 #381460
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Clutch not engaging no matter where its adjusted
While holding the clutch in have someone put their foot against the rear tire. See if they will stop the rotation and how much pressure it will take to do so and hold it from turning. The heavier the oil in the trans, the more it will spin and the more pressure it will take.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 10 Jul 2010 07:25 by otakar.
