Newbie sprocket offset question?
- jayw704
07 Jul 2010 09:28 #380785
by jayw704
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Newbie sprocket offset question? was created by jayw704
So this may seem like a stupid question...
If the chain is not rubbing frame, tire or swing arm I know i can use a laser level to see if they line up front and rear sprocket...
What is the negative effect other than excelerated chain and sprocket wear if its a few millimeters off?
1978 KZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 Jul 2010 10:39 #380800
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Newbie sprocket offset question?
The chain needs to ride centered on both sprockets as much as possible. It is okay if they are off slightly, so long as it isnt riding the edges.
If not/way off/riding edges hard, it will basically GREATLY accellerate wear, like were talking a chain a season.
If it is drastically off, the link can ride off the sprocket and lock your tire underway, which can kill you.
(Not likely to happen, but can occur).
Make sure they ride true.
GL.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- jayw704
07 Jul 2010 10:42 #380801
by jayw704
1978 KZ1000
Replied by jayw704 on topic Newbie sprocket offset question?
Thank you.
1978 KZ1000
