82 KZ550 No accelleration and knocking noise
- Morgoth
06 Jul 2010 13:11 #380603
by Morgoth
82 KZ550 No accelleration and knocking noise was created by Morgoth
I bought my 550 a month ago with 15K miles on it, and naturally, as a new rider, I had no idea that it might leak oil. That is, of course, until it ran out on me. I refilled it with oil immediately after that, and a knocking noise from the cam shaft seems to have started up. I put some Engine restore in it and ran it for a bit, but the problem didn't go away. I also found some metal shavings in the filter when I replaced it. I know this isn't good, but the worst part is, the bike seems to have problems accelerating in 3rd gear. I'm not even sure where to start to diagnose the problem, so any help that could be provided would be excellent.
Thanks in advance.
Thanks in advance.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
06 Jul 2010 15:46 - 06 Jul 2010 15:48 #380634
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic 82 KZ550 No accelleration and knocking noise
If you ran out of oil that means that crital parts of the engine were not recieveing proper lubrication for some time.
Basically, you could have widespread damage and might be riding a bomb with a knock like that.
It needs to be completely torn down, and every bearing hand spun to unsure no movement/wear beyond tolerences.
Or just get yourself a new engine that runs fine and swap out the scrap.
Fiddling with the carbs and ignition is NOT where to start, get the engine physically sound first.
GL!
GL!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 06 Jul 2010 15:48 by TeK9iNe.
