clutch/trans...
  • ipeightball
  • ipeightball's Avatar Topic Author
clutch/trans...
06 Jul 2010 10:09
#380572
i broke a clutch cable the other day. i was in 2nd gear when it went, slamed into gear when it broke. replaced the calbe now it cant shift higher than second gear while rolling. if i put it up on the center stand i can shift all the way up and back down but the shifter feels stiff. any ideas?
1980 kz550 c ltd
  • BSKZ650
  • BSKZ650's Avatar
Re: clutch/trans...
06 Jul 2010 11:24
#380579
what size bike?
77 ltd1000, current rider
76 kz900, just waiting
  • ipeightball
Re: clutch/trans...
06 Jul 2010 11:37
#380586
kz550 c ltd 1980
1980 kz550 c ltd
  • TexasKZ
  • TexasKZ's Avatar
Re: clutch/trans...
06 Jul 2010 11:45
#380587
ip8,
It is unlikely that the tranny has been damaged. KZ trannies are renowned for their robustness. Double, triple, quadruple check that the new cable was adjusted exactly as the factory shop manual requires. Skipping steps or even doing them out of order can lead to a great deal of frustration. This is especially true of the KZs that have an adjuster in the middle of the cable.
It is considered respectful around here to put your basic bike info in your signature line. If you have multiple bikes, clearly state which one is giving you grief, since diagnosis and treatment can vary quite a bit from one model to the next.
  • TexasKZ
  • TexasKZ's Avatar
Re: clutch/trans...
06 Jul 2010 11:46
#380588
Ooops, type too slow. :blush:
  • ipeightball
Re: clutch/trans...
06 Jul 2010 11:51
#380589
Thanks TexasKZ. I will look about the cable.
1980 kz550 c ltd
  • TexasKZ
  • TexasKZ's Avatar
Re: clutch/trans...
06 Jul 2010 12:01
#380595
You're welcome. Let us know how it comes out.
  • ipeightball
Re: clutch/trans...
06 Jul 2010 12:17
#380599
will do. how do i post a sig line on my posts?
1980 kz550 c ltd
  • ipeightball
Re: clutch/trans...
07 Jul 2010 06:18
#380749
thanks for all the help folks. it turned out to be a linkage problem. the cover plate on the shifter was out of line and binding my shifter.
1980 kz550 c ltd
