- Thank you received: 1
82 GPz750 Muffler Questions
- nicksorg
06 Jul 2010 05:11 #380544
by nicksorg
1982 Kawasaki KZ1000-K2
82 GPz750 Muffler Questions was created by nicksorg
My bike sat for 9 years and the pipes are full of nuts, nesting material, etc. I pulled them off the bike and have a few questions:
1.) There appears to be a bunch of silver steel woool material at the end of the pipe. Do the stock mufflers have packing or did the animals move it in?
2.) I'm wondering if I can get to it by drilling out the rivets in the end cap. Has anyone done that and if so, can I just replace the rivets?
Thanks
Nick
Thanks
Nick
- hocbj23
- Visitor
06 Jul 2010 05:18 #380546
by hocbj23
Replied by hocbj23 on topic 82 GPz750 Muffler Questions
PO probably put it in there to quiet the mufflers down.bj
- nicksorg
06 Jul 2010 05:32 #380550
by nicksorg
Replied by nicksorg on topic 82 GPz750 Muffler Questions
I'll compare the one muffler I was looking at to the other once I separate it from the head pipes, but it may take awhile as its on there pretty good.
- nicksorg
08 Jul 2010 11:03 - 08 Jul 2010 11:19 #381064
by nicksorg
Has anyone drilled the endcap out of one of these mufflers?
Both stock mufflers are filled with nuts, etc. from sitting so long. I've taken a bunch of stuff out already, but I figure I can get to the rest of it by taking the endcap off. I drilled out the rivets but its not budging.
Nick
Nick
Last edit: 08 Jul 2010 11:19 by nicksorg.
- MFolks
- Thank you received: 540
08 Jul 2010 15:09 #381128
by MFolks
Replied by MFolks on topic 82 GPz750 Muffler Questions
Take a hammer and small punch and drive the rivets out, then get some sheet metal screws,turning them in where the rivets were.
Use a vice grip and grab the screws as a pulling place. Before trying to remove the end caps, spray the joints with PB-Blaster or other penetating oil for a few days.
- mjg15
09 Jul 2010 13:02 #381285
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic 82 GPz750 Muffler Questions
Use a slide-hammer to pop them out.....and take some measurments for me ....I need a pair of those end caps.
I either have to make some or find a pair, the previous owner removed them and it sounds like junk w/out them (IMO). I posted on here a couple times looking , but havent come up with a pair yet
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- nicksorg
12 Jul 2010 01:24 #381897
by nicksorg
It took awhile this weekend, but I got them off. I used sheet metal screws with a slide hammer to start it. Then once I got it separated, I used a l-hook that came with my slide hammer in each of the rivet holes and worked it off.
I'll measure it up and trace one of the caps and post back.
Thanks
Nick
Thanks
Nick
- nicksorg
12 Jul 2010 18:17 #382082
by nicksorg
I just cleaned out all the nestinng and nuts, etc. out of the pipes. Whatever animals were living in there had a nice thing going for awhile. Anyways, I put the caps back on tonight with rivets. Thanks again for the help.
- MFolks
12 Jul 2010 18:45 #382099
by MFolks
Rodents love to put all kinds of food for the future in what they consider a safe place.
Mice will build nests inside engine compartments of seldom driven cars, and chew up motorcycle seats stored away.
- nicksorg
13 Jul 2010 05:59 - 13 Jul 2010 06:01 #382224
by nicksorg
Attached are the specs for my muffler caps in PDF format. I traced the cap and included some measurements.
Nick
Nick
Attachment 82GPz750_MufflerCap.zip not found
Last edit: 13 Jul 2010 06:01 by nicksorg.
- mjg15
13 Jul 2010 12:37 #382308
by mjg15
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
Thanks
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
