New rider, Oil changes?
- 81KZ750H
09 Apr 2006 13:50
I recently bought my first bike, a 1981 KZ 750H, and am wanting to do an oi change, i bought 4 litres of 10w 40 motor oil and a new filter, my question is where is the old filter located on engine? I took a quick look but do not want to unbolt things when im not 100% shure, your help is appreciated...
- Mark Wing
Re: New rider, Oil changes?
09 Apr 2006 14:33
Welcome to the site. you can get lots of info in the archives. Look on the bottom of the motor for a round cover just a little bigger than the filter with a bolt in the center of it. If it has aftermarket exhaust you may have to remove it.
Mark
Post edited by: Mark Wing, at: 2006/04/09 17:34
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- wireman
09 Apr 2006 14:36
there should be an oil drain plug under bike,the oil filter should be off to one side from it big bolt looks like drain plug but will be holding a big round disc with fins your oil filter is on top of it.
