Cam cover gasket.
- bhardy501
04 Jul 2010 16:59 #380238
by bhardy501
1980 KZ1000B LTD
Cam cover gasket. was created by bhardy501
Hey guys, My KZ1000 is leaking a little oil around the cam cover gasket. Is this a fairly easy change or is it a major job to change that gasket out?
1980 KZ1000B LTD
- MFolks
- Thank you received: 540
04 Jul 2010 17:07 #380239
by MFolks
Replied by MFolks on topic Cam cover gasket.
Easy job, pull the tank,and coils(make a diagram as to where the primary wires go).
Scrape the old gasket off using a sharp piece of Lexan or Plexiglass.Wipe the sealing surfaces with lacquer thinner and let dry.
Try not to drop any old gasket inside the cam areas. The rubbber cam plugs should be replaced too as they shrink from heat and age.
- bhardy501
04 Jul 2010 19:56 #380287
by bhardy501
1980 KZ1000B LTD
Replied by bhardy501 on topic Cam cover gasket.
Thanks. Does the cam cover ends come with a gasket as a set or do you have to get them seperate?
1980 KZ1000B LTD
- MFolks
04 Jul 2010 20:18 #380290
by MFolks
I'd check with
www.z1enterprises.com
for new cam plugs and valve/cam cover gasket.
When I had my 1977 Kz1000, the cam plugs and cam cover were seperate items.
