KZ1100 A2 valve cover bolt leak
- danyboy
04 Jul 2010 05:58 #380110
by danyboy
KZ1100 A2 valve cover bolt leak was created by danyboy
- Old Man Rock
- Thank you received: 225
04 Jul 2010 07:48 #380121
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ1100 A2 valve cover bolt leak
First off welcome Danyboy...
Shim/shim tools are for measuring your valve clearances & swap shims if required... Not required for a new cover gasket only... Same time, while in the top end, check your clearances...
As for the cam end caps... Most of the OEM are rubber end caps, if hard, cracked, dried out probably not a bad idea to change but again not required....
Excellent source for KZ parts @ Z1 Ent and APE...
www.z1enterprises.com/catalog.aspx?pid=KP441
kzzone.com/
And most definitely... get yourself a manual, preferably OEM shop manual....
OMR
kzzone.com/
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
