- Thank you received: 29
Engine / Transmission Oil Leak
- ed spangler
- Tennessee Z
03 Jul 2010 07:54 #379890
by ed spangler
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
Engine / Transmission Oil Leak was created by ed spangler
Hello Good Morning.
I have a 75 Z1-B
Had polished Front Sprocket Side Cover Off for replacing front drive sprocket, noticed oil leaking from where gear selector shaft exits the "Mission Cover" on that side of engine / transmission as Kaw calls it on parts diagram
( What a name?!), Anyway, I have ordered the 3 seals that go on gear selector shaft, 2 in the outer polished cover , one inside the "Mission Cover" ( All 3 are the same seal according to Kaw), the Mission cover gasket and the output front sprocket /drive shaft seal that is in mission cover... I think that should cover parts ??( Not 100% sure, never had this off before!!??) Anyone had this "Mission Cover" off before? Anything to watch out for? Or special tips on removal or re-installation? Did I miss any seals or gaskets?? that i need to order in addition to what i have already ordered?
Thanks!!
I have a 75 Z1-B
Thanks!!
- PLUMMEN
- Thank you received: 104
03 Jul 2010 07:56 #379894
by PLUMMEN
Replied by PLUMMEN on topic Engine / Transmission Oil Leak
dont forget the gasket for backside of mission cover
- MFolks
- Thank you received: 540
03 Jul 2010 08:46 #379920
by MFolks
Replied by MFolks on topic Engine / Transmission Oil Leak
Use a piece of sharpened plastic like Plexiglass or Lexan to remove any old gasket, this way the soft Aluminum cover won't be gouged and possibly leak.
- ed spangler
- Tennessee Z
05 Jul 2010 06:19 #380342
by ed spangler
Replied by ed spangler on topic Engine / Transmission Oil Leak
Hi Plummen
I only saw one gasket for the "Mission Cover", I did order it, is there more than one?
Thanks
ED
Thanks
ED
- ed spangler
- Tennessee Z
05 Jul 2010 06:22 #380344
by ed spangler
Thanks
Will keep that in mind, Normally after I remove something like the "Mission Cover" I will wash it in the parts washer to remove excess grease, dry with air and then bead blast and rewash to remove bead balsting material, redry with air
apply thin film of grease to new gasket and reapply cover.
After of course installing new seals. I saw 3 seals for Selector shaft ,one seal for output sprocket shaft and one gasket for mission cover, hopefully that covers the materials.
Thanks Again
ED
Thanks Again
ED
- PLUMMEN
05 Jul 2010 08:02 #380358
by PLUMMEN
the paper gasket was the one i was refering to if you dont already have it,seals mission cover to cases
- ed spangler
- Tennessee Z
05 Jul 2010 09:26 #380372
by ed spangler
If thats Kaw part number 14058-004
Got it on order.
Hope I got the number right, went to Z1's site used the link to Kaw parts, thats what it looked like.
Sent that info to Z1 asked them for the parts.
Thanks
ED
Got it on order.
Thanks
ED
