- Thank you received: 3
billet aluminum cam endcaps for J bikes
- 9am53
- homebrew, and some bbq
02 Jul 2010 04:38 #379606
by 9am53
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
billet aluminum cam endcaps for J bikes was created by 9am53
I have developed a slow annoying leak out of 2 cam endcaps on my bike. I just don't trust the rubber ones. APE has some nice endcaps for the older KZ bikes, but none for the J, does anybody know if there are any good quality aluminum caps for J bikes?
'84 GPz900r
'71 CB350
- trianglelaguna
- Thank you received: 235
02 Jul 2010 05:01 #379609
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic billet aluminum cam endcaps for J bikes
did you silicone a clean end cap in a clean surface in place before istalling cover and let it dry some....
1976 KZ900
2003 ZX12R
2007 FZ1000
- 9am53
02 Jul 2010 05:16 #379614
by 9am53
'84 GPz900r
'71 CB350
Replied by 9am53 on topic billet aluminum cam endcaps for J bikes
I followed all the instructions I was given. I also retorques the endcaps when I retorqued the head bolts (nuts). It's only 2 of them, and one is actually leaking from the bolt that goes down through the rubber endcap, so I think a copper washer would fix that one, but the other one is leaking around the rubber.
'84 GPz900r
'71 CB350
- trianglelaguna
02 Jul 2010 05:20 #379617
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
i have seen some purty ones for j-heads so i know they are around
1976 KZ900
2003 ZX12R
2007 FZ1000
- 9am53
02 Jul 2010 05:25 #379618
by 9am53
'84 GPz900r
'71 CB350
cool, at least I know they are out there, I emailed Z1E so hopefully they can track some down for me.
'84 GPz900r
'71 CB350
- dshelly
- Thank you received: 5
02 Jul 2010 05:45 #379620
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic billet aluminum cam endcaps for J bikes
Hey 9am53 I can help you out on the cam plugs. Send me a PM. I'll give you some more info.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- 9am53
02 Jul 2010 05:46 #379621
by 9am53
'84 GPz900r
'71 CB350
done
'84 GPz900r
'71 CB350
- Motor Head
- Thank you received: 391
02 Jul 2010 07:08 #379626
by Motor Head
Replied by Motor Head on topic billet aluminum cam endcaps for J bikes
When you put it together again, or do the bolts now to stop 1 leak, I put Teflon tape on the thresds of the bolts. Since the holes can be like a drain as they are located at the low point of the 1/2 circle. I can't think of why they did this, there are thousands of engine designs with these 1/2 circles, and no bolt goes through them. The type of sealer you use on them is the trick, it must stand up to oil, but remain semi pliable as those rubber ones will shrink up slightly with heat over time.
- 9am53
02 Jul 2010 07:10 #379627
by 9am53
'84 GPz900r
'71 CB350
good idea on the teflon tape.
'84 GPz900r
'71 CB350
- 9am53
06 Jul 2010 06:08 #380552
by 9am53
'84 GPz900r
'71 CB350
well, I tightened the bolts that go through the endcaps down a bit more and through my weekend of riding they seemed to hold the oil in. I hope that lasts because washing oil off after every ride sucks!
Anyways, DShelly is a machinist in the process of making some J end caps, and Z1E is in the process of developing some of their own, so by the time I am ready for a valve adjustment I will have a source for end caps, sweet!
'84 GPz900r
'71 CB350
- StreetfighterKz
- Thank you received: 117
07 Jul 2010 08:49 #380775
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic billet aluminum cam endcaps for J bikes
www.americanclassix.com/kawa_maintenance.html
Look about 3/4 down the page and there is a listing for billet J-model end caps. $39.95 for a set.
Later, Doug
Later, Doug
1989 Vmax
- 9am53
07 Jul 2010 08:54 #380777
by 9am53
'84 GPz900r
'71 CB350
Thanks, I never found those! Z1E and Dave up above both said around 30 bones so I will wait for whoever gets er done first.
'84 GPz900r
'71 CB350
