About to explode, cam timing problems!
- Adamsz1
I have taken the cams out of this thing ATLEAST 50 times, Trying different ways to get it set. I have failed and im afraid if I tighten down these cam caps anymore I'm going to end up with some stripped bolts. Think i need a manual tensioner? New cam chain? Any help would be appreciated
- larrycavan
- Visitor
You're timing is correct. Cam chain wear will cause situations like this. You won't get the marks any closer than what they are now if the cam chain or idlers are worn out.
A 75 wouldn't have had an auto tensioner. They were manual adjust tensioners. Consult your service manual for adjustment procedure.
As you turn the motor over, watch the cam chain up by the top idler. See if you get slack sections passing through there.
I would also pull the top idler and see if the gear wobbles around.
Another probelm area is the little shoe in the front of the block. They break or wear through. No amout of cam chain tensioner adjustment will correct that situation. Look down inside there and see if you can spot a problem with the shoe.
- trianglelaguna
- Thank you received: 235
but my first take was that the marks were for checking clearances and the end of the cam marks are the ones used most often for installation...eggs level and facing out ....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Adamsz1
I notice in the photo it looks like the chain has been replaced with a masterlink type chain. Did you recently replace the chain or is that how you bought the bike?
Thats not a real picture of my bike, I didn't replace any cam chain related peices.
I was saying auto tensioner as in, it has a spring that automatically takes up the tension when you loosen up the screw. Not like an ape where you have to manually adjust
Yes, about every half turn on the crank there quite a bit of slack by the top idler.
It has side to side play, but no up and down play
Are you speaking of the peice that the adjuster pushes on, that then pushes on the cam chain?
- larrycavan
- Visitor
The shoe I mentioned can't be replaced without pulling the block off. It's in the front of the block. It's held in by a screw from the bottom side. Quite common to see them broken.
They're difficult to verify with the motor in the frame because it's hard to see down in there. You can pull the cams out, move the wiring aside and shine a light down inside the cam chain tunnel for a visual inspection.
That chain slack every half revolution isn't good. I wouldn't ride the bike with that situation going on.
bikebandit.com has schematics that will show you the components if you don't have a manual.
- Adamsz1
- Old Man Rock
- Thank you received: 225
Which chain did you order/install.. 122 or 124 link?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Adamsz1
What I ment in the above posting is, the chain was the original chain, but it was working fine 300 miles ago. Though, I do remember it had alot less slack under the idler pulley when the crank was turned.
- Thank you received: 2098
Be certain about location of the T mark, as differentiated from the numeral "1".
Before adjusting the tensioner, use 17 mm nut (NOT 13 mm bolt head) to hand rotate crankshaft to TDC, aligning T mark with permanent case mark. This puts most cam chain slack at rear where the rub block presses against it.
Adjusting the automatic cam chain tensioner:
The "automatic" refers to pressure against the rub block which reduces chain slack.
Loosen the lock nut, then loosen the bolt. A spring inside the advancer is calibrated to set the correct pressure on a rod that presses against the rub block (that's the "automatic" part, otherwise equivalent to "finger tightening" a manual adjuster).
Then tighten the bolt (which holds the push rod in its freshly automatically adjusted position), and then tighten the lock nut to secure the bolt. "Snug" is sufficient for both the bolt and lock nut.
The automatic tensioner cannot be adjusted too often.
[Click on image to enlarge view.]
- Adamsz1
[Add checked items to Pick-List] REF NUMBER PART NUMBER DESCRIPTION QUANTITY US CA CN REMARKS
[Add to Picklist: 12057-001]
1 12057-001 IDLER ASSY 1
[View Supersession]
[Add to Picklist: 112G0635]
2 112G0635 BOLT-UPSET,6X35 4
[Add to Picklist: 92027-155]
3 92027-155 COLLAR 4
[Add to Picklist: 92075-119]
4 92075-119 DAMPER RUBBER 2
[Add to Picklist: 92075-120]
5 92075-120 DAMPER RUBBER 2
[Add to Picklist: 12057-002]
6 12057-002 IDLER ASSY 2
[View Supersession]
[Add to Picklist: 12052-005]
7 12052-005 SHAFT,GUIDE ROLLER 2 Z1-A/B, Z1
[View Supersession]
[Add to Picklist: 12052-003]
8 12052-003 SHAFT,CAM CHAIN GUIDE 1
[Add to Picklist: 92075-232]
9 92075-232 RUBBER,GUIDE ROLLAR 4 USE WITH 12052-005, USE WITH 12052-002
[Add to Picklist: 12048-001]
10 12048-001 TENSIONER ASSY,CHAIN 1
[Add to Picklist: 12055-002]
11 12055-002 ROLLER,CAM CHAIN GUID 1
[Add to Picklist: 92075-123]
12 92075-123 DAMPER RUBBER 2
[Add to Picklist: 21070-003]
13 21070-003 CHAIN,CAM SHAFT 1
[Add to Picklist: 12054-001]
14 12054-001 PUSH ROD,CAM CHAIN 1
[Add to Picklist: 92081-107]
15 92081-107 SPRING,TENSTIONER 1
[View Supersession]
[Add to Picklist: 11009-1980]
16 11009-1980 GASKET,TENSIONER 1
[View Supersession]
[Add to Picklist: 12049-1003]
17 12049-1003 HOLDER,TENSIONER 1 Z1, Z1-A/B
[View Supersession]
[Add to Picklist: 410B0600]
18 410B0600 WASHER PLAIN 6MM 2
[View Supersession]
[Add to Picklist: 112G0620]
19 112G0620 BOLT-UPSET,6X20 2
[View Supersession]
[Add to Picklist: 311B0600]
20 311B0600 NUT 6MM 1
[Add to Picklist: 92003-093]
21 92003-093 BOLT,TENSIONER ADJUST 1
[View Supersession]
[Add to Picklist: 12053-019]
22 12053-019 GUIDE,CAM CHAIN 1 E/NO. 062686--
[View Supersession]
[Add to Picklist: 220B0610]
23 220B0610 SCREW PAN HEAD 6X10 1
