popping in to Neutral while shifting
01 Jul 2010 13:59 #379478 by cromick
popping in to Neutral while shifting was created by cromick
I have a 82 650 CSR and sometimes it'll pop into Neutral when I'm shifting up from 1st to 2nd. Anybody else have that problem or know if I might be just not kicking it up hard enough?
  • WABBMW
  • Let The Good Times Roll !
01 Jul 2010 14:17 #379483 by WABBMW
Replied by WABBMW on topic popping in to Neutral while shifting
I've have the same motorcycle and had this happen, but very rarely - probably once in 5,000 miles.
Just be sure your shift is very deliberate and positive. These bikes shift so easily that it is easy to just nudge the lever with your left foot instead of making a positive motion. If your technique is right, and it still does this, then someting else may be taking place, which someone else will have to chime in with what it is.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
01 Jul 2010 17:29 #379525 by Lazyman06
Replied by Lazyman06 on topic popping in to Neutral while shifting
I had a Honda 919 that would do this alot and my Hyosung does it. I just made sure I shifted up real hard.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
01 Jul 2010 17:40 #379531 by dragsta
Replied by dragsta on topic popping in to Neutral while shifting
if you have aftermarket pipes and free-flow air cleaner, your bike will pop out the exhaust. richen your idle mixture screws and it will stop.
  • trianglelaguna
01 Jul 2010 18:15 #379539 by trianglelaguna
Replied by trianglelaguna on topic popping in to Neutral while shifting
it is a worn part in the shift mechanism imo....mine all do it cause of my wheight-big feet-and modified shift linkage....it is not gonna do much in the short term and will just be annoying..i'm sure it is not so great for the valves to get big dose often but oh well,mine seems to not care....i have to be positive in my shifts when under a load or when haulling ass away from a stop as i go up through the gears......it can be fixed but is a lot of work and may just reappear imo.....most old kz's have a false nuetral between second and third anyways and that is often where the missed shift occurs as you leave a dead stop...imo...
i would just shift harder with the left toes....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
01 Jul 2010 22:20 #379587 by cromick
Replied by cromick on topic popping in to Neutral while shifting
Thanks guys. I often times think that I just need to kick that up with a little more emphasis, and when I do consciously think to do that, I don't have the problem. It does sometimes, also, go into neutral as I'm downshifting to first, although that hasn't happened with much frequency as the other issue.
02 Jul 2010 09:36 #379654 by dragsta
how can engine "popping" have anything to do with loose shift linkage? i'm guessing that your bike is popping out the exhaust. if so it will do so when you let off the gas with the bike in gear too. richen your idle mix on each carb until the problem stops. simple....
02 Jul 2010 10:38 #379665 by cromick
I didn't mean popping in the literal, noisy sense. I meant it as in "goes into unexpectedly". Like you "pop in" to someone's house.
  • trianglelaguna
02 Jul 2010 10:46 #379666 by trianglelaguna
:dry:
1976 KZ900
2003 ZX12R
2007 FZ1000
02 Jul 2010 16:14 #379747 by Lazyman06
awkwaaard
  • Motor Head
02 Jul 2010 16:36 #379754 by Motor Head
Replied by Motor Head on topic popping in to Neutral while shifting
Is your shift lever tight on the shift shaft? This can come to be slightly loose causing a further travel of the toe to get the correct travel of the shift shaft. The splines here can get pretty loose.
  • trianglelaguna
02 Jul 2010 19:51 - 02 Jul 2010 19:57 #379791 by trianglelaguna
oh i'm sorry...now i get it you said ...popping....my bad...:ohmy:
(youtube)
if you do watch this ..hit the lower right four arrow screen enlarge icon...the guys little subtle stuff is lost in mini view imo.......i think you may need to rejett as the popping will annoy the neighbors doggies....
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 02 Jul 2010 19:57 by trianglelaguna.
