New exhaust rejet?
- Omaha Rider
28 Jun 2010 23:25 #378927
by Omaha Rider
1978 KZ650 SR D
New exhaust rejet? was created by Omaha Rider
So I want to get some Vance & Hines exhaust for my kz650. If I do, will I need to "rejet" or "resync"/"tune" my carbs? I was going to get them synced soon because one of the headers is turning yellow. Should I just wait till I get the exhaust to work on the carbs?
1978 KZ650 SR D
- bountyhunter
- Thank you received: 337
28 Jun 2010 23:45 - 28 Jun 2010 23:48 #378928
by bountyhunter
Replied by bountyhunter on topic New exhaust rejet?
I would certainly wait to get the carbs tuned until you have your new exhaust. That said, V+H pipes should be easy to dial in as long as you don't screw with the airbox.
FYI, even tuned perfectly I will wager your pipes will still turn blue at the first bend. That is unless you get double walled pipes or treat the inside of the pipes with something.
Last edit: 28 Jun 2010 23:48 by bountyhunter.
