exhaust baffle
- arizcoin
exhaust baffle
27 Jun 2010 19:04
I have a 1980 KZ1000 LTD. Will it harm engine or performance (ie.. carbs or mileage) if I take the baffle out of my V/H 4 in 1 exhaust?
- bountyhunter
Re: exhaust baffle
27 Jun 2010 19:36
It will make it run leaner which could potentially harm the engine if you don't rejet it.
Re: exhaust baffle
27 Jun 2010 19:37
arizcoin
Welcome to the board. This topic has been discussed a bunch, please check out the search function. There is a recent discussion here - kzrider.com/index.php?option=com_kunena&...ew&catid=3&id=378046
- TerryK
Re: exhaust baffle
27 Jun 2010 20:52
arizcoin wrote:
Thing is, why would you want to? Trying to out-loud the Harley guys? lol
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- davel
Re: exhaust baffle
27 Jun 2010 22:49
arizcoin wrote:
Give it a shot. Removing 1 screw will do it. Will likely give you more top end but sacrifice bottom end and require rejetting.
Installing a competition baffle is the best of both worlds.
- larrycavan
Re: exhaust baffle
28 Jun 2010 03:35
arizcoin wrote:
I run the street baffle with no packing in my 1200 motor. Good sound, not annoying, good all around performance.
Larry C
Larry C
- Oldwolf
Re: exhaust baffle
28 Jun 2010 14:41
Same as Larry C. but ll05cc and Kerker Street Baffle no packing.
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
- TeK9iNe
- What did you do!?!
Re: exhaust baffle
28 Jun 2010 15:59
It may or may not require re-jetting, and will make a flat spot in your power down low.
No to mention blow your damn ears apart after even a short ride!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- hocbj23
Re: exhaust baffle
28 Jun 2010 16:02
Street baffle and packing in mine.Quiet,plenty 'o power and doesnt po the neighbors and local gendarmes.Nice sound as well.bj
