Exhaust Gaskets
26 Jun 2010 08:51 #378293 by gaillarry
Exhaust Gaskets was created by gaillarry
Got a brain fart, when installing new exhuast gaskets, does the flat side go into the port or the round side?
1977 KZ1000
1985 Gpz750
26 Jun 2010 09:37 #378299 by Patton
Replied by Patton on topic Exhaust Gaskets
gaillarry wrote:
...when installing new exhuast gaskets, does the flat side go into the port or the round side?
FSM doesn't say one way or the other.
Don't think it matters.
I usually install all four with the same orientation, but likely doesn't matter either.
Regarding installation of head gasket, the folded over metal edge should be upward.
Good Fortune! :)
26 Jun 2010 09:48 #378304 by Old Man Rock
Replied by Old Man Rock on topic Exhaust Gaskets
Something Larry and Plum informed me of for I had the same question way back when.....
Flat side to Port....
This way the curved rounded side will compress fit to exhaust tube...
Also, use some Permatex high temp copper sealer on the flat side to hold the gaskets in place. This will also help in reducing exhaust leaks....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
26 Jun 2010 09:52 - 26 Jun 2010 09:54 #378306 by Patton
Assure old gasket is removed.
May sometimes discover two old gaskets in the same head port.
The old gaskets get so carbon encrusted inside the ports, it may be difficult to discern the gasket as distinct from the port area.
May clean the head port area with acetone and q-tip.
Doesn't need to be spotless.
Could also dab some high temp copper silicone on the gasket when "sticking" it inside the port.
Helps hold the gaskets in position while installing header pipes, so the split collars, clamps, gaskets, don't all keep falling apart while trying to reassemble. :pinch:
Good Fortune! :)
Edit: Yikes! OMR beat me to the punch . . . again! :laugh:
Last edit: 26 Jun 2010 09:54 by Patton.
26 Jun 2010 09:57 #378307 by RonKZ650
Replied by RonKZ650 on topic Exhaust Gaskets
Either way the copper collapses and seal the exhaust. It doesn't make $0.02 difference which way they go.
26 Jun 2010 10:33 - 26 Jun 2010 10:35 #378313 by bountyhunter
Replied by bountyhunter on topic Exhaust Gaskets
I agree no matter which way it faces. I use scotchbrite pad to clean hard carbon off the seat and end of header.
On mine, I have two use two gaskets on the RH side port to get a seal. I use a couple of tiny dots of crazy glue to hold those two together during installation.
Last edit: 26 Jun 2010 10:35 by bountyhunter.
26 Jun 2010 10:45 #378319 by Old Man Rock
Regarding exhaust gaskets thickness....
Wasn't there some mentioning where thicker gaskets off a Suzki or similar for this? I forget now....
Anyone have a link?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
26 Jun 2010 11:28 #378324 by MFolks
Replied by MFolks on topic Exhaust Gaskets
I think Jeff at Z1 mentioned using Suzuki gaskets as they are a little bit thicker than what Kawasaki sells.
26 Jun 2010 14:17 #378364 by JMKZHI
Replied by JMKZHI on topic Exhaust Gaskets
The few times I've done it, I've put a small slather of grease on the flat sides then "stick" them into the exhaust ports.
26 Jun 2010 18:33 #378449 by Buda
Replied by Buda on topic Exhaust Gaskets
I used the suzuki exhaust gaskets this spring...they look twice as thick and made it kind of a pain to get the bolts started. No leaks at all to this point.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
  • TeK9iNe
  • What did you do!?!
26 Jun 2010 18:43 #378451 by TeK9iNe
Replied by TeK9iNe on topic Exhaust Gaskets
The kawasaki gaskets work just fine, but not for re-use. Thats a maybe... if your lucky.
The greese to hold them in trick works wonders.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
11 Jul 2010 17:47 #381772 by Yowman
Replied by Yowman on topic Exhaust Gaskets
I just changed my exhaust gaskets and the copper gasket goo is the way to go. I smear a little on the exhaust pipe, stick the gaskets to them and stick em in the holes and bolt it down, tightening one side of each clamp a little at a time. Be careful that your clamps are moving in evenly so that you don't break one.
Original owner of a stock, 1977 KZ1000-LTD
