Exhaust Gaskets
- gaillarry
1977 KZ1000
1985 Gpz750
- Thank you received: 2098
...when installing new exhuast gaskets, does the flat side go into the port or the round side?
FSM doesn't say one way or the other.
Don't think it matters.
I usually install all four with the same orientation, but likely doesn't matter either.
Regarding installation of head gasket, the folded over metal edge should be upward.
- Old Man Rock
- Thank you received: 225
Flat side to Port....
This way the curved rounded side will compress fit to exhaust tube...
Also, use some Permatex high temp copper sealer on the flat side to hold the gaskets in place. This will also help in reducing exhaust leaks....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
May sometimes discover two old gaskets in the same head port.
The old gaskets get so carbon encrusted inside the ports, it may be difficult to discern the gasket as distinct from the port area.
May clean the head port area with acetone and q-tip.
Doesn't need to be spotless.
Could also dab some high temp copper silicone on the gasket when "sticking" it inside the port.
Helps hold the gaskets in position while installing header pipes, so the split collars, clamps, gaskets, don't all keep falling apart while trying to reassemble. :pinch:
Edit: Yikes! OMR beat me to the punch . . . again! :laugh:
- RonKZ650
- Thank you received: 240
- bountyhunter
- Thank you received: 337
On mine, I have two use two gaskets on the RH side port to get a seal. I use a couple of tiny dots of crazy glue to hold those two together during installation.
- Old Man Rock
Wasn't there some mentioning where thicker gaskets off a Suzki or similar for this? I forget now....
Anyone have a link?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
- Thank you received: 540
- JMKZHI
- Thank you received: 48
- Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- TeK9iNe
- What did you do!?!
- Thank you received: 28
The greese to hold them in trick works wonders.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Yowman
Original owner of a stock, 1977 KZ1000-LTD
