- Thank you received: 1
Cracking my case . . . help!
- Kawi // Twin
The engine has 36,000 miles on it. I rode the bike for a few weeks after my friends and I cleaned and re-built the carbs. The engine runs fine. I originally used walnut shells to blast some of my engine covers to see how well it would clean the cases intact of the heavy oxidation, but it did not clean them the way I wanted. I found that porchev914 had his engine cases cleaned up at a local shop close to my powdercoaters, for a relatively low price and his cases look better than new. I originally did not want to crack the cases as the engine was running well, but the rest of the bike (at least in my head) will look great but I will have a dingy engine sitting in all the rebuilt goodness. Plus I have never taken an engine apart before. I am mechanically inclined though. With a full set of tools, but no specialized ones for taking apart an engine.
Anyways, I decided that I need to dissemble the engine and have the cases cleaned. My question is, what should I look for when I look at the the insides to see if anything needs replacing? I will get a complete gasket kit and shim the valves. I have a FSM and have been reading it lately. Should I replace anything else as a matter of course? I want to keep as much of the original parts as possible to keep my costs as LOW as possible as I AM on a budget and trying to stay in the budget.
Any suggestions or links to an easy step-by-step dissembly process? Thanks for your help so far!
1978 KZ650 B2
forums.kz650.info/index.php?topic=3569.0
2009 Kawasaki 650R - yes it is a Ninja, but not really
1985 Ninja 900 or GPz900 for everyone else outside the USA
1984 Ninja 900 for restoration
- turboguzzi
- Thank you received: 72
jpavlov.files.wordpress.com/2008/12/kawk...76fullwith78sup5.pdf
they detail step by step what to do
TG
- kzdrummer
- Kawi // Twin
Check on the impact driver, I have already removed the covers that had phillips heads. Will probably replace with an Allen head set for future removals. I cleaned out the clutch bands about a month ago when I found that they were sticking. How long are they supposed to last?
I replaced the points with a 1980 KZ750 electronic ignition already. Should I replace the cam seals as a matter of course?
Thanks in advance
1978 KZ650 B2
- porchev914
- Thank you received: 19
FRANKEN Z!
- turboguzzi
Thanks turboguzzi. I do have a paper copy of my 1978 KZ650B2, the link you sent me was to a KZ750 2-cyl, do you have one of the 4-cy; KZ650 so I don't ruin my book?
Thanks in advance
no problem, I just saw that your nick is kawi twin, so...
- Kawi // Twin
1978 KZ650 B2
