- Thank you received: 1
Finding seals and O rings?
- polkat
24 Jun 2010 22:30 - 24 Jun 2010 22:32 #378088
by polkat
Finding seals and O rings? was created by polkat
It's my '82 KZ750H3. The output shaft (that drives the front sprocket) is leaking from it's seal. It also has a somewhat smaller O ring in front of the seal that I suspect is shot as well. Also, the big O ring that goes around the oil filter cover seems to be leaking a bit as well (although it's fairly new). My question is, where can I find these rings and seals without paying a million for them? I'm poor!
Thanks!
Thanks!
Last edit: 24 Jun 2010 22:32 by polkat.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
- JR
- Thank you received: 448
25 Jun 2010 04:41 #378105
by JR
Replied by JR on topic Finding seals and O rings?
Usually when I buy an oil filter the big O ring comes with the filter..... so your next oil and filter change should take care of that one.
- Motor Head
- Thank you received: 391
25 Jun 2010 06:35 - 25 Jun 2010 06:38 #378122
by Motor Head
Replied by Motor Head on topic Finding seals and O rings?
Looks like there are $4-5 a seal for all of they stuff to seal the side cover, and there is 2 seals where the shifter goes through the sprocket cover. Looks like you need your VIN # to get the right seals as there is a change mid production.
92050-024 should be the output seal.
Last edit: 25 Jun 2010 06:38 by Motor Head.
- warmmushroom
25 Jun 2010 08:30 #378144
by warmmushroom
Replied by warmmushroom on topic Finding seals and O rings?
You can buy o-rings at most transmission supply shops if you know the size...you are looking at pennies per ring that way.
