- Thank you received: 391
Reground Cam? Anybody
- Motor Head
24 Jun 2010 19:00 #378052
by Motor Head
Reground Cam? Anybody was created by Motor Head
Any of you guy's had some Cams reground to a performance spec? Reputable regrinders info and cost would be nice, maybe an exchange program where they exchange cores for Cams that are done, cuts down on waiting.
- otakar
24 Jun 2010 19:14 #378055
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Reground Cam? Anybody
I have had two sets of KZ1300 cams hard welded and re-ground by Web-Cam. Re-grinds are usually about 50% more expensive than new high performance cams and make sense if there is nothing available for your application. re-grinds are also quite a bit more durable than new cams because of the hard-weld lobes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
24 Jun 2010 20:48 #378075
by larrycavan
Replied by larrycavan on topic Reground Cam? Anybody
Regrinds are for custom spec or where there are no longer cores available.
Megacycle & Web will hardweld and regrind. Like Otto said, it's expensive.
If it's for a 650KZ, I don't believe anyone has cores anymore so hard weld is the only option.
- otakar
24 Jun 2010 23:04 - 24 Jun 2010 23:05 #378093
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
He didn't specify what bike but WEB-CAM still shows a good selection of 550, 650, and 750 cams in stock. I just presumed it was for his 1000 or 1100.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Jun 2010 23:05 by otakar.
- larrycavan
- Visitor
25 Jun 2010 03:57 #378098
by larrycavan
otakar wrote:
Web reqiured cores for every 650 I've spoken to them about in the past few years.
- Motor Head
25 Jun 2010 06:16 #378121
by Motor Head
Replied by Motor Head on topic Reground Cam? Anybody
Just a inquiry at the moment as I gather info. Not a lot of manufactures making new cams for a lot of old motors/ cars as well. Regrinding used to be pretty cheap for some cams, but it would cut the base circle down, and make the cam ramps steeper, unless spending the bucks for hard welding, it would depend on the grind wanted. seems like a billion years ago now, but one of the performance shops I worked at in the 80's used to carry a reground line, along With Norris.
