Andrews 2X cams, what lift and duration?
- 2006hhr
- larrycavan
- Visitor
Did a search, the only info i came up with did not list the cams by 1X, 2X etc. Just wondering what they spec at. Bike is a 1979 KZ650 SR. Running a Mac megaphone exhaust, KZ900 carbs and pod filters, jetted accordingly.
Here ya go
Chart is for Kz900 - 1000
You want their #25 Grind for a 650. That's their version of a 2x for those motors. .360" lift & 260 Dur. @.030" checking lift. MUST CHECK PISTON TO VALVE CLEARANCE WITH THAT GRIND.
The #20 Grind is .350 /252 If using stock pistons would be a safer choice for that motor.
- Nebr_Rex
- Thank you received: 300
Andrews had numbers 10,15,20,25,30,35 and 40.
I have the spec. sheet on all of them, let me know what no.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- 2006hhr
- larrycavan
- Visitor
Thanks guys, still bidding, just wondering how much work it would need to install them.
If they're 2x, STOP BIDDING...they don't fit your bike.
- 2006hhr
- kawsakiman
- Thank you received: 6
kawsakiman@rochester.rr.com
- PLUMMEN
- Thank you received: 104
- larrycavan
- Visitor
#10 - 10/46 236* .330 - Bolt in Stock Buckets & springs.
#15 - 12/52 244* .340 - For 750 Motors
#20 - 16/56 252* .350 - Stock Buckets & Springs Torque from 3000 up
#25 - 20/60 260* .360 - Stock Springs OK - Piston Clearance needs checking
#30 - 25/35 270* .370 - Big CC street motors, aftermarket buckets & springs Power from 3000 up.
#35 - 27/67 274* .380 - 800cc & up Power from 5000 up
#40 - 21/61 262* .392 - Drag and Big Street Motors Springs and Buckets Required. Broad torque to 11000.
- 2006hhr
