- Thank you received: 1
Wrong spark plugs?
- polkat
24 Jun 2010 15:35 #377994
by polkat
Wrong spark plugs? was created by polkat
Went to buy new plugs for my 1982 KZ750H3 today. The manual calls for NGK BR8ES plugs, but the dealer sold me BR9HS plugs and said they would work fine. Will they? Doesn't seem right.
- Motor Head
- Thank you received: 391
24 Jun 2010 15:40 - 24 Jun 2010 16:26 #377998
by Motor Head
Replied by Motor Head on topic Wrong spark plugs?
They are a step colder heat range, do you have a high compression motor or stock? Stock, then stock plugs, B8ES, 2.50 ea at Z1. Dealer should know this is the wrong plug, it will build up residue and try to foul if your jetting is of even a little.
Oh and those are only 1/2" reach/ length, you need 3/4"
Find B8ES, or many other plugs from many different manufactures, take those others back.
Last edit: 24 Jun 2010 16:26 by Motor Head.
- KZ250LTD
- Thank you received: 16
24 Jun 2010 15:58 #378002
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic Wrong spark plugs?
Just go to your local auto store, part source, napa, anywhere. I've never had a problem finding the plugs at regular places.
79 KZ1000ST
Past:
Many.
- MFolks
- Thank you received: 540
24 Jun 2010 16:55 #378012
by MFolks
Replied by MFolks on topic Wrong spark plugs?
I've used Denso W24-ESU or NGK B8ES sparkplugs in my bike for many years with no problems.
- polkat
24 Jun 2010 22:26 #378087
by polkat
Replied by polkat on topic Wrong spark plugs?
Well...heh...the dealer apologized for his stupidity (although, of course, he didn't admit that) and gave me the right plugs (BR8ES). So I'm covered. Thanks all.
- bountyhunter
- Thank you received: 337
24 Jun 2010 22:56 #378091
by bountyhunter
Replied by bountyhunter on topic Wrong spark plugs?
polkat wrote:
NO. They are colder than B8ES and B8ES are already very cold plugs. The 750 twins run B6ES which are two steps hotter than B8ES.Went to buy new plugs for my 1982 KZ750H3 today. The manual calls for NGK BR8ES plugs, but the dealer sold me BR9HS plugs and said they would work fine. Will they? Doesn't seem right.
