- Thank you received: 1
backfiring kz750 twin
- KZCool
23 Jun 2010 12:16 #377761
by KZCool
1976 KZ750 hardtail
backfiring kz750 twin was created by KZCool
so I went for as ride today, and everything was fine untill about two miles out when i felt my bike start to jerk, like a cylinder was cuting out. I pulled in the clutch, and let off the gas and it died, i let the speed of the bike start it agin then when I got to a stop sign it died. I finally got it kick started again but with a lot of tries ending in backfires. the kick starter would litterally throw my leg off of it and I could see some small amounts of smoke coming from the carbs. I have ordinaly 10w 40 in it right now. Could this be from the summer heat and heat of the engine making the oil too thin? or is it more likely something more serious?
1976 KZ750 hardtail
- hocbj23
- Visitor
23 Jun 2010 12:28 #377763
by hocbj23
Replied by hocbj23 on topic backfiring kz750 twin
How long since u have replaced plugs,wires, and looked at the timing advancer? Any issues with leaks at the fuel petcock?Tank clean? Have the carbs been cleaned or rejetted?If the bike is "kicking back" as u describe,I would suspect timing is off.Just some items to start thinking about.bj
- Capt America
- Born Bad
23 Jun 2010 20:49 #377877
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic backfiring kz750 twin
It almost sounds like you lost a spring off of your timing advancer during your ride, or your advancer stuck with the arms out.
Sorry but, LOL, can these old twins kick back or what eh! :woohoo:
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- bountyhunter
- Thank you received: 337
23 Jun 2010 21:38 #377881
by bountyhunter
Replied by bountyhunter on topic backfiring kz750 twin
Garbage in a main jet will do that. Guess how I learned that.... could also be timing advancer, coil, plug wires, etc.
- steell
24 Jun 2010 06:15 #377898
by steell
Replied by steell on topic backfiring kz750 twin
Malfunctioning charging system will do that also
- Thank you received: 2098
24 Jun 2010 09:25 #377933
by Patton
Replied by Patton on topic backfiring kz750 twin
While at it, might as well also assure valve clearances are adjusted to spec, especially the intake valves.
A too tight intake valve clearance can cause backfire through the carb.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
24 Jun 2010 10:47 - 24 Jun 2010 10:49 #377952
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic backfiring kz750 twin
steell wrote:
BWAH!?! Where the hell have you been man!... :laugh:
My guess... timing issue, there you have it!
:silly:
this is true...Malfunctioning charging system will do that also
:silly:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 24 Jun 2010 10:49 by TeK9iNe.
- KZCool
24 Jun 2010 15:21 #377990
by KZCool
1976 KZ750 hardtail
Replied by KZCool on topic backfiring kz750 twin
I thought timing too. I just installed a dyn s system, timed it with a timing light, and rejetted the carbs for a k&n air filter. the timing is dead on, but the peice of the dyna system that goes into the advancer didn't fit right so i put an o-ring in the gap. tightened it up enough that it doesn't wobble anymore but it does seem a bit tight. it moves fine and returns but there is a bit of space were the advancer doesn't return the peice all the way back. Could new springs fix this?
1976 KZ750 hardtail
- Motor Head
- Thank you received: 391
24 Jun 2010 15:37 #377995
by Motor Head
Replied by Motor Head on topic backfiring kz750 twin
That doesn't sound right?
But a stuck advancer? How does it make a bike quit? Hard to start, kick back on kicker, sure. Maybe you need to look farther, possible fuel problem, as suggested check the valves, and cam timing, compression test, to make sure its not mechanical. Do you use a in-line filter? Could you have a electrical/ voltage problem? AS already suggested.
- KZ250LTD
- Thank you received: 16
24 Jun 2010 16:01 #378003
by KZ250LTD
79 KZ1000ST
Past:
Many.
Replied by KZ250LTD on topic backfiring kz750 twin
Check compression and spark, could be valves, carbs, timing, anything. If you check the obvious and they're good then you can check them off the list and you'll have a better idea of what the problem could be.
79 KZ1000ST
Past:
Many.
- KZCool
26 Jun 2010 16:37 #378407
by KZCool
1976 KZ750 hardtail
Anything hu? that sux lol. I guess I'l just start with the simple stuff.
1976 KZ750 hardtail
