- Thank you received: 16
Identify this foreign material
- KZ250LTD
Not sure what this is. Clutch plate? Starter clutch maybe(I haven't checked it but the starter was working so I doubt it)?
Suggestions anyone?
79 KZ1000ST
Past:
Many.
- larrycavan
- Visitor
Looks like friction plate shavings and a dab of silicone sealer.
- taildragger1197
- Thank you received: 17
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
- Vter Bob
- Thank you received: 4
OH NO! NOT ANOTHER "ORANGE" FILTER! :blink:
This is way out of my expertise, but I found some stuff that looked similar to that under the stator cover of my 1000. It was the glue they used to affix the magnets to the rotor. With the volume you show in the pics I doubt that's what it is. I don't think pieces that large could make it into the oil pan. Is it hard or pliable?
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
- larrycavan
- Visitor
Not to make light of your problem but...
Oh yea...you could well be right.
I took a second and better look at the pics. The piece on the glove looks like silicone at quick glance but when you go back up and look at the other pics, it does look a lot like the epoxy sealer used on the rotor magnets. The ST would have that type of rotor....
- MFolks
- Thank you received: 540
- KZ250LTD
Edit:
and the oil filter appeared to be intact, don't think it is filter debris especially because it is so hard
79 KZ1000ST
Past:
Many.
- larrycavan
- Visitor
I doubt it is silicone, forgot to mention that it is very hard. That's why I figured it might be clutch plates. There was no sign of it in the barrels or on the pistons and just from a quick glance there doesn't seem to be much up inside the cases but the motor hasnt run for about a year so it may well have just had time to drop down
Edit:
It's most likely the epoxy from the edge of the rotor magnets then. Yank the cover.
- KZ250LTD
I'll strip the rest off and once its back together run it and flush the oil a couple of times before any serious riding (it'll be awhile, this is just a side project). Does the epoxy need to be there? Should I replace it?
79 KZ1000ST
Past:
Many.
- MFolks
The trouble I see with using another adhesive would be in balancing it evenly. You might have to have the rotor re-glued. I wonder if a motor rebuilding shop could vacuum impregnate the magnets in a furnace(of course magnets and high temperature dont mix well).
- KZ250LTD
79 KZ1000ST
Past:
Many.
- bountyhunter
- Thank you received: 337
It looks Irish to me......
