csr1000 ignitor
- kwak650
19 Jun 2010 17:19 #376865
by kwak650
csr1000 ignitor was created by kwak650
My csr1000 is having issues with the ignitor box,it seems to be shorted to ground internally.I have a dyna 111 box from a 650 just wondering is there anyway to wire it to my csr1000.Thanks
- otakar
19 Jun 2010 18:14 #376876
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic csr1000 ignitor
Just get another igniter on eBay. They are quite common. I have 4 spare units for mine. You can pick them up for anywhere between $25 and $50. The Dyna is a deferent system.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
19 Jun 2010 18:17 - 19 Jun 2010 18:21 #376878
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
If you want a really good igniter, build one yourself from two GM modules. There is a design by one of our members here and it rocks.
www.kzrider.com/archive/viewthread.php?tid=27518
This link will not work right you will have to coppy and paste it.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Jun 2010 18:21 by otakar.
- JMKZHI
- Thank you received: 48
20 Jun 2010 07:11 #376983
by JMKZHI
Replied by JMKZHI on topic csr1000 ignitor
From the cross-reference in the diagrams at Kawasaki.com:
KZ1000-M1 (CSR) (1981)
21119-1041 Igniter
Model (26):
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 (Police 1000) (1982)
KZ1000-P2 (Police 1000) (1983)
KZ1000-P3 (Police 1000) (1984)
KZ1000-P4 (Police 1000) (1985)
KZ1000-P5 (Police 1000) (1986)
KZ1000-P6 (Police 1000) (1987)
KZ1000-P7 (Police 1000) (1988)
KZ1000-P8 (Police 1000) (1989)
KZ1000-P9 (Police 1000) (1990)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-B1 (GPz) (1981)
KZ1100-B2 (GPz) (1982)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
The supersession shows these part numbers:
21119-1356 Igniter Newer
21119-1041 Igniter
21119-1030 Igniter Older
21119-1041 Igniter
Model (26):
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
21119-1041 Igniter
- kwak650
20 Jun 2010 07:56 #376993
by kwak650
Replied by kwak650 on topic csr1000 ignitor
Thanks for the crossreference info I should be able to find something to match.If not I might try to build one I am hearing alot of good things about the GM HEI mock up.
- H1Vindicator
- Thank you received: 52
20 Jun 2010 08:02 - 21 Feb 2013 01:52 #376995
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 21 Feb 2013 01:52 by H1Vindicator.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
20 Jun 2010 11:10 #377046
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic csr1000 ignitor
H1Vindicator wrote:
B-B-B - BINGO! :laugh: :laugh:
Soooo true!
The downside to buying used electrical parts is that you never really know if it's any good until you install it on the bike.
Soooo true!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- MFolks
- Thank you received: 540
20 Jun 2010 13:23 #377075
by MFolks
Replied by MFolks on topic csr1000 ignitor
If you plan on doing the GM electronic ignition module design by Loudhvx, I've got cross index part numbers for other manufacturers:
GM HEI Ignition Modules (4 Pin)
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
- otakar
20 Jun 2010 19:33 #377140
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
I've been very lucky. All three that I have bought turned out good. Actually the failure rate on these units is very low, unless you mismatch a set of wrong aftermarket coils which are less than 2.2 Ohms. We have had one member here that did have a problem with one but it is a very rare problem.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
