- Thank you received: 15
Dyna S Install / Spark advancer
- madmatt1
13 Jun 2010 16:49 #375519
by madmatt1
1977 KZ1000 LTD
1977 KZ1000A
Dyna S Install / Spark advancer was created by madmatt1
Can someone please tell me the correct way to remove the spark advancer bolt on a KZ1000? I'm installing a Dyna S ignition, & saw that this bolt has two different size hexes on it and I just want to make sure I remove it the correct way to avoid damage
1977 KZ1000 LTD
1977 KZ1000A
- otakar
13 Jun 2010 17:07 #375523
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Dyna S Install / Spark advancer
Hold the larger one with a box wrench to prevent it from turning while loosening the smaller one.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- madmatt1
13 Jun 2010 17:15 #375524
by madmatt1
1977 KZ1000 LTD
1977 KZ1000A
Replied by madmatt1 on topic Dyna S Install / Spark advancer
i tried to do this, but after i put a wrench on the larger one, there's not enough of the top nut exposed to get a good bite on it. have to find some slim wrenches i guess?
1977 KZ1000 LTD
1977 KZ1000A
- hocbj23
- Visitor
13 Jun 2010 17:52 #375539
by hocbj23
Replied by hocbj23 on topic Dyna S Install / Spark advancer
17mm box end on big one,13mm socket on small one?bj
- Thank you received: 2098
13 Jun 2010 19:16 #375567
by Patton
Replied by Patton on topic Dyna S Install / Spark advancer
Sometimes an air impact wrench (maybe electric impact wrench) will loosen and remove the bolt from end of crankshaft without needing to hold the 17mm nut.
The bolt turns counter-clockwise to loosen.
- madmatt1
14 Jun 2010 10:34 #375648
by madmatt1
1977 KZ1000 LTD
1977 KZ1000A
Thanks I'll keep that in mind for sure - I think I'll run over to Sears or somewhere like that today, & see if they have some slim profile box wrenches. There was just absolutely no way for me to fit two box wrenches, or a box wrench & socket on there, I would just end up stripping the hex on the bolt. I'm kind of puzzled & feeling stupid because it seems like everybody else has installed this ignition, and nobody ever mentions running into this problem!
1977 KZ1000 LTD
1977 KZ1000A
- hocbj23
- Visitor
14 Jun 2010 10:44 #375651
by hocbj23
nothing stupid about asking.Lots of stupid in not asking and screwing something up.Plus some of us are stupid amd damn lucky--dont ask me how I know.Lol.bj
14 Jun 2010 11:30 #375663
by Patton
Could also put bike in gear and apply rear brake to hold crankshaft in position while turning out the bolt.
- madmatt1
14 Jun 2010 15:23 #375734
by madmatt1
1977 KZ1000 LTD
1977 KZ1000A
Excellent! That was my initial thought, but when I tried that the first time I must not have been putting enough mustard on the brake because the bike was wanting to roll across the garage floor as I was trying to turn the bolt. It was on there REALLY tight, but I got it. Thanks for the help!
1977 KZ1000 LTD
1977 KZ1000A
- Oldwolf
14 Jun 2010 15:43 #375741
by Oldwolf
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
Replied by Oldwolf on topic Dyna S Install / Spark advancer
I used the 17mm open end wrench in my old factory tool bag. It is as you described slimmer than the standard style wrench. I had the same problem as you described but had forgotten.
