Z1 Exhaust drain ports
- rfisher7381
13 Jun 2010 15:16 #375499
by rfisher7381
Z1 Exhaust drain ports was created by rfisher7381
Any suggestions on how to unplug the drain ports. I have tried a small dental pick and a 1/16" drill without success. I thought about just drilling a small 1/16" hole but decided I'd check the collective wsidom here first. Thanks for any suggestions.
- Thank you received: 2829
13 Jun 2010 19:11 #375563
by 650ed
Replied by 650ed on topic Z1 Exhaust drain ports
I've used a drill bit between my fingers, but my drain ports weren't plugged up solid. You might try a tiny Philips screwdriver if you have one. Ed
- Jeff.Saunders
14 Jun 2010 06:08 #375622
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Z1 Exhaust drain ports
Many of the original Z1 enhausts had a manufacturing problem where the head pipe extended too far into the muffler and blocked the drain hole. Kawasaki issued a maintenance release on this to drill another hole further back...
With genuine exhausts, it's worth removing them from the bike over the winter months and hanging them up to drain.
You also need to avoid short trips that build condensation in the pipes. Realistically a ride of 30-50 miles is needed to remove any built up condensation in the pipes.
Z1 Ent on Facebook,
- rfisher7381
14 Jun 2010 17:47 #375766
by rfisher7381
Replied by rfisher7381 on topic Z1 Exhaust drain ports
Thanks for the suggestions.
