- Thank you received: 57
z900 oil cooler take-off leaking oil
- willemZ900
- Z1B 4 ever
13 Jun 2010 14:26 #375490
by willemZ900
z900 oil cooler take-off leaking oil was created by willemZ900
Hi Folks,
Still having problems with oilleaking from the oil take-off.
I already renewed the 18mm O-rings. Now i am thinking of putting bigger O-rings in it. Somebody had this problem before? Need advise/help Where to buy bigger O-rings?
Willem
Willem
- mark1122
- Keep twisting it
- Thank you received: 109
14 Jun 2010 15:03 #375730
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic z900 oil cooler take-off leaking oil
i have never had a leak on mine. have u already tryed silicone on the o ring? thats what i put on most of my seals, and gaskets.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Oldwolf
14 Jun 2010 15:17 #375733
by Oldwolf
1977 KZ1000A1, 1105cc,Mikuni RS34mm FS, K&N Pods,Kerker 4/1,Dyna S Ign,Coils & Plug Wires,Progressive Sup. Front&Rear, Derale Oil Cooler.
Replied by Oldwolf on topic z900 oil cooler take-off leaking oil
My after-market Oil Cooler Fittings that came with the Oil Cooler did leak after installing (if this is what you are refering to). I had to remove and sand the fittings flat with sand paper. Both fittings looked flat but when you slid them across a piece of fine grit sand paper you could tell the fittings needed to be "faced or machined flat"(the term used by a Machinist friend when I told him what I did)I then re-installed and have not had any problems. Hope this helps.
- MDawnz1
- Thank you received: 27
17 Jun 2010 00:51 #376272
by MDawnz1
1974 Z1a, still 903
Replied by MDawnz1 on topic z900 oil cooler take-off leaking oil
That sanding trick always works ,,,,,,,,BUT
Tape the sandpaper down on a piece of glass,
The thicker the better,
Wet or dry sandpaper is best,
The black stuff.
Wet it with a few drops of something slick,just a bit.
For small parts I just spit on it, I know ,nasty.
If you want to see what you are doing, color the surface with a sharpie or other marker.
For a new seal, or any seal.
Look in your phone book for an industrial bearing&seal supply house.
The now make seals that seal on all 4 surfaces.
The black stuff.
1974 Z1a, still 903
