81 KZ750H2
- lrburke
- cobura
- forever 2 wheels
- Thank you received: 3
1979 KZ650B3
- lrburke
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- Thank you received: 2098
Hey Guys, I have put several post on here about this frustrating bike so here comes another!! I just got finished putting Dyna 2.2 ohm coils on it and that went fine. I am getting good voltage to them. This bike has a Vance and Hines exhaust on it with baffles in it and these goofy pod filters I have never even seen before! I have went through the carbs and the jetting I am presently at is stock pilots,65 primaries and 135 secondaries! The fuel mixture screw is at 2.5 turns out. The valve clearances are within spec and I did a leakdown test on all 4 cylinders and they were really good! This thing just can't sustain an idle after it heats up. I am 100% sure the carbs are spotless and the pilot jets are clear. I have rebuilt hundreds of carbs to this point and always have had superb idling. I even hooked my inductive timing light up to all 4 plug wires individual;ly while the idle is falling off and the flashes remain steady all the way until it stalls. The only thing I have yet to replace is the carb holders but I did spray WD40 and carb cleaner around them thoroughly and was no change! Does anybody have any idea at all what could cause this? I am at wits end with this thing! Let me know if you need any more info!
What ignition system (stock)?
After stalling out, will engine immediately crank and run again? Or does it need to first cool before it will again run?
Will engine continue running normally while riding the bike unless permitted to idle? In other words, would it run just fine for say a straight stretch of 50 miles, and everything be okay until coming to a halt at idle?
Was suspicious of valve clearances until reading that they were to specs. (Still a little suspicious.) :lol:
