Head gasket
  • LTD
  • LTD's Avatar Topic Author
Head gasket
07 Apr 2006 07:17
#37540
Will a motor have compression with a blown head gasket?
  • BARNEYHYPHEN
  • BARNEYHYPHEN's Avatar
Re: Head gasket
07 Apr 2006 07:39
#37544
Depends where the "blow" is but my $0.02 worth is that YES, extremely likely.
  • steell
  • steell's Avatar
Re: Head gasket
07 Apr 2006 08:13
#37552
The only times I have seen zero compression on a motor are when the piston was either gone or had a big hole in it, or the head was broken off a valve (and that usually punches a hole in the piston).
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
Re: Head gasket
07 Apr 2006 18:58
#37700
You certainly could lose compression through a
blown head gasket.
1979 kz 1000 06 katana 750
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: Head gasket
07 Apr 2006 19:14
#37708
Is this a rhetorical question or is there some earthly or ethereal context?
