- Thank you received: 1
How many r's can a kz 1000 buzz before damage
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- hardr0ck68
Hardrock, you also have to consider the distance from the center of the valve to the outside edge. A smaller valve can flow more at small lifts then a large valve (in relationship to its size). Think of it as a circumference to surface area ratio. Plus a new R6 has some pretty wicked cams.
I know about the r6 cams, they are so aggressive the bike doesn't get out of its own way till like 9,000. But from 9-16 it is a straight beast!
So one bigger valve just can't keep up? I know that is the real limitation of these old beast (that and the air cooling... ) Is there any effective work around without forced induction or sewer pipe ports?
1977 kz650 c1
- Jeff.Saunders
Jeff.Saunders wrote:
The other factor is the crank. The crank is a roller bearing crank - and much over 10,000rpm the rollers stop rolling and start sliding - and that's not good...
Jef;
That is interesting. Do you feel that that is the same for the Suzuki cranks too. The pro stock bikes operate from 10,000 to 13,500. You think they are just sliding the rollers on a pass?
Wonder why they don't just build those cranks with a bronze bushing instead of rollers.
Something to think about.
I have often thought I would want to take the time to figure out what the rpm of one of those rollers is at 10,000 crank speed. Same with a wheelie bar wheel at 230 mph.
Hi Jay, I would imagine the old Suzuki 8 valve bikes of Terry Vance and the like from the late 70's had the same issue. One of the east coast racers running a very serious naturally aspirated Kawasaki drag bike runs a redline over 11,000 - but they do have to replace cranks many times during the season. They've scrounged a few old cranks from me to rebuild.
The rollers are one of the main limitations of the old Z1 cranks - although an incredibly tough crank, they are constrained by the rollers. But to be able to run just 2-3 psi oil pressure is nice - it means in normal use, the cranks are nearly impossible to break...
www.z1enterprises.com
Z1 Ent on Facebook,
- BSKZ650
- Thank you received: 14
and dont the F1 engines they are running use roller bearing cranks,I seem to remember somthing like that a few years back, and they turn the hell out of them.
back to the roller bearing thought, it dosent need a lot of oil pressure so its more or less just keeping some lubrication to the contact area and has less resistance.
am I wrong thinking like this?
77 ltd1000, current rider
76 kz900, just waiting
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- hocbj23
- Visitor
hocbj23 wrote:
i didnt mean anything personal,its just everybody seems to get hooked like a big fish at some point and try and build a motor that would be right at home in a 400lb bike built for the track and wonder why its so tempermental on the street.been there and done that myself :laugh:Not sure how to respond.Other than V and H pipe,jetting to match the pipe and a Dyna S ignition and coils,plus a Satrab oil cooler,bike is pretty much stock ("J" cams installed this weekend)..Unless the PO did something to it before he stored it in pieces 20 years ago,it just happens to be a very good running old bike (after 2 years of putting it back together)..So,I didnt "build" it to make power at 9500 rpm - it just does (plus I am no engine builder)..If I ever have to tear it down and redo it,I will certainly heed ur advice.However,the way the bike runs now,it will probably outlive me in its current state.
Didnt take it personally-seen too many of your posts here to believe u would aim a personal shot at someone.Just responded to let u know that at age 71 I dont need a bunch of hp to scare myself silly and the way the old bike runs now is just fine with me.Take care.bj
- PLUMMEN
- Thank you received: 104
- PLUMMEN
the centrifical forces overpower the bearings ability to roll at a certain speed basically locking it against the outside of the bearing cage at a certain speed like an amusement park ride :laugh:ok, gonna be dumb, but how does a roller just slide past?
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
