Smokin!!!
- Fozzie
10 Jun 2010 14:13 #374920
by Fozzie
1982 KZ1000J
Smokin!!! was created by Fozzie
So the ol KZ was smokin from the crankcase thru the little elbow below the carbs...is this something to worry about? Also has a bit of oil coming out from around the same fitting.
1982 KZ1000J
- muddy1
- 1980 Kz1000 LTD B4
10 Jun 2010 14:32 #374926
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic Smokin!!!
I would worry, check your oil level, do a compression check, have your valve shims benn checked?
Muddy1
Muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- larrycavan
- Visitor
10 Jun 2010 16:38 #374940
by larrycavan
Replied by larrycavan on topic Smokin!!!
A bit of blow by past the rings most likely. Run it and keep an eye on your oil level.
- keith1
- Thank you received: 2
10 Jun 2010 17:02 #374944
by keith1
Replied by keith1 on topic Smokin!!!
larrycavan wrote:
i would second that....
- Fozzie
10 Jun 2010 19:15 #374985
by Fozzie
1982 KZ1000J
Replied by Fozzie on topic Smokin!!!
It only smokes sometimes...but keep an eye on the oil...check...and rock on Whooo!!!
1982 KZ1000J
