Do I need a new clutch cable on my 84 LTD 550?
- dlare
10 Jun 2010 12:45 #374907
by dlare
Do I need a new clutch cable on my 84 LTD 550? was created by dlare
My son-in-law just bought a 1984 550 LTD that has the one piece clutch cable, that connects to a pivoting lever on top of the case.
He asked me to ride it an the first thing I noticed was that the clutch had no real friction zone. It was either fully engaged or fully disengaged. And it engages right at the end of the travel just before the lever is fully released. There's about 1/4" of slack.
I've been riding for 28 years on cable and hydraulic clutches, but never had one that acted like this.
Any ideas?
Thanks,
Deano
Any ideas?
Thanks,
Deano
- Motor Head
- Thank you received: 391
10 Jun 2010 12:53 #374911
by Motor Head
Replied by Motor Head on topic Do I need a new clutch cable on my 84 LTD 550?
A new set of clutch springs and a oil change to some thing more wet clutch friendly. Does it also have the adjustment at the side cover for the worm gear? Look at the side cover and take out the 2 screws for the small rectangular cover, inside is a lock nut and adjusting screw that should be done before the cable. This operates the rod that actually pushes to release/ engage the clutch.
- dlare
10 Jun 2010 13:18 #374916
by dlare
Replied by dlare on topic Do I need a new clutch cable on my 84 LTD 550?
Thanks for the speedy reply!
No little side cover on this one. I think the 82's and older had that style. On his, the cable connects to the pivoting arm outside the case.
I'll try to change the oil to the Rotella that I use in my 'Wing.
Thanks,
Dean
Thanks,
Dean
- dlare
23 Jun 2010 06:56 - 23 Jun 2010 06:57 #377722
by dlare
Replied by dlare on topic new clutch cable didn't help (84 LTD 550)
Well, the new clutch cable didn't seem to help
This is the newer design without the ball bearing push rod adjustment. I have the lever adjusted with a little slack. Changed the oil to 15W50 m/c oil.
Symptoms:
1. The clutch hangs a little with the lever pulled in to the grip (bike wants to creep forward in gear).
2. The full engagement doesn't happen until the lever is fully released. Then it's like full engagement. bang.
There seems to be no real "friction zone".
Ideas?
Dean
Symptoms:
Ideas?
Dean
Last edit: 23 Jun 2010 06:57 by dlare.
- hocbj23
- Visitor
23 Jun 2010 07:40 #377725
by hocbj23
Replied by hocbj23 on topic new clutch cable didn't help (84 LTD 550)
how many miles on the bike?May be time to replace the friction discs and springs.bj
- JMKZHI
- Thank you received: 48
23 Jun 2010 07:52 - 23 Jun 2010 07:55 #377727
by JMKZHI
Replied by JMKZHI on topic new clutch cable didn't help (84 LTD 550)
Do you have a repair manual for the bike?
Sometimes the Clymer manual is ambiguous or in error in regards to how to do the clutch adjustment.
According to the diagrams at Kawasaki.com, the clutch cable has a barrel adjuster on the end near the clutch release pivoting arm(?).
PS: I don't know anything about your type of clutch adjuster.
Last edit: 23 Jun 2010 07:55 by JMKZHI.
- H1Vindicator
- Thank you received: 52
23 Jun 2010 08:12 - 20 Feb 2013 20:23 #377730
by H1Vindicator
Replied by H1Vindicator on topic ----
Last edit: 20 Feb 2013 20:23 by H1Vindicator.
- dlare
23 Jun 2010 08:40 #377734
by dlare
hocbj23: The bike has about 14,000 miles.
H1Vindicator: I'll adjust the slack down a bit to see if it gets rid of the "drag" at idle with the lever fully pulled in.
JMKZHI: I have the Kaw service manual. Mine does have an adjuster near the pivot arm, but my take on this is that it's only if you need more adjustment than you can get with the adjuster at the lever.
Thanks for all the input guys.
Deano
Deano
- hocbj23
- Visitor
23 Jun 2010 09:19 #377735
by hocbj23
Deano: 3mm slack (gap) is what manual calls for at the clutch arm.That isnt very much slack.bj
- Capt America
- Born Bad
- Thank you received: 1
23 Jun 2010 11:07 #377748
by Capt America
Capt A merica
1983 K1 750 twin
Ontario, Canada.
Replied by Capt America on topic Do I need a new clutch cable on my 84 LTD 550?
Is this your clutch style??
If so the adjustment where the arrow is pointing is just the course adjustment that is in the middle of the cable for the other style.
So I suggest you turn your fine adjuster at the handle all the way in, and take up the cable slack at the course adjuster until you have less than a 1/4 inch at the handlebars, then bring it down to the 3mm they suggest.
I've always found with this style that the clutch tends to drag a bit when the engine is hot. So if I'm sitting at a light for a long period, or stuck in traffic I just toss it in neutral.
Capt A merica
1983 K1 750 twin
Ontario, Canada.
- dlare
24 Jun 2010 03:38 #377889
by dlare
The photo is very similar to mine. I was able to get it adjusted pretty good. I bent the actuator pivot lever upward so each pull of the lever would get me more throw at the pivot. Then I adjusted the slack to a very tiny amount. Now it works pretty good.
Thanks for all the input!
Deano
Deano
