- Thank you received: 2236
The wrong kind of Kaw triple
12 Jun 2010 09:41 #375255
by TexasKZ
Nope. The fuel level directly impacts the air-fuel ratio. At small throttle openings, all or nearly all of the fuel flows through the low speed circuit. As the throttle is opened more, the carb transitions from low speed (pilot) operation to the main jet. In both cases, what comes out of the jets in not pure gasoline, it is an air-fuel mix. If the fuel level is too high, then fuel can enter the emulsion passages that are supposed to introduce air into the fuel, hence causing a rich condition. If the fuel level is really high, it can force gasoline through the main jet before there is demand for it, causing an even richer condition.
If the fuel level is too low, it can cause too much air to be introduced into the jets, or even prevent the jets from picking up any gasoline at all.
Replied by TexasKZ on topic The wrong kind of Kaw triple
I'm still a bit confused, though. Even if the #2 carb were overfilling, wouldn't the needle allow about the same amount of fuel into the combustion chamber?
- Skonnie Boy
12 Jun 2010 09:56 #375259
by Skonnie Boy
'77 kz650C
Replied by Skonnie Boy on topic The wrong kind of Kaw triple
Of course, the slow jets. I get it now.
Possibly unrelated: Clymer says 650 carbs either had a pilot screw or an air screw. Mine has both. Is Clymer wrong or did someone Frankenstein my carbs? Doesn't seem possible to combine the two...
'77 kz650C
