- Thank you received: 10
Horrible exhaust leak on cylinder 3?
- Kitten Tooth
Thanks guys,
KT
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- bountyhunter
- Thank you received: 337
I never do.Should i use anti-seize on the bolts before i bolt the headers back on?
Kitten Tooth wrote:
I do mine by hand, don't torque.Also, would you guys recommend torquing the header bolts?
Kitten Tooth wrote:
Yes, that will throw the jetting miles off. Also, save some money for all the tickets you will be getting.Also, my muffler is really nasty on the right side. If i hacked my mufflers off, would i need to re-jet?
- mark1122
- Keep twisting it
- Thank you received: 109
Kitten Tooth wrote:I do mine by hand, don't torque.Also, would you guys recommend torquing the header bolts?
Kitten Tooth wrote:Yes, that will throw the jetting miles off. Also, save some money for all the tickets you will be getting.Also, my muffler is really nasty on the right side. If i hacked my mufflers off, would i need to re-jet?
X2
i have 2 use 2 gaskets per pipe on my Kerker.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- ezrider714
- Thank you received: 38
Hand tightened will work fine, don't overtighten.
Never a good idea to lose the mufflers
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
- bountyhunter
I have to use double gasket rings on one side of my 750 twin, but not the other. Not sure why, but it won't seal that side with only one.i have 2 use 2 gaskets per pipe on my Kerker.
- Thank you received: 2098
For example, the oem split collars for a certain model may be sightly different length than the split collars furnished with a new accessory exhaust system.
Easy to get these mixed around in the parts drawer, and not notice small differences in length.
