Tach gear block off plate/plug
- chrispysaki
08 Jun 2010 08:52 - 08 Jun 2010 08:55 #374378
by chrispysaki
Tach gear block off plate/plug was created by chrispysaki
Anyone know where I can get one of those block off plates/plugs to cap off the hole in the head for the tach gear for a kz750?
I talked to Z1 and the guy there said the ones they stock are for the 1000 motors.
I saw this one on bike bandit, but there's no photo and I don't know if it's even the same thing I'm thinking of.
www.bikebandit.com/product/A4050991
Thanks,
Chris
Thanks,
Chris
Last edit: 08 Jun 2010 08:55 by chrispysaki.
- otakar
08 Jun 2010 08:55 #374379
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Tach gear block off plate/plug
As Far as I knew they were the same.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- chrispysaki
08 Jun 2010 13:02 #374418
by chrispysaki
Replied by chrispysaki on topic Tach gear block off plate/plug
Yeah, it seems weird that they would be different. Do you know anything about the one at bike bandit?
- larrycavan
- Visitor
09 Jun 2010 05:19 #374575
by larrycavan
Replied by larrycavan on topic Tach gear block off plate/plug
They can be made out of the OEM tach drive itself. Remove the driven gear and plug the hole.
- sramsey216
09 Jun 2010 09:34 #374619
by sramsey216
1980 KZ1000 LTD
Replied by sramsey216 on topic Tach gear block off plate/plug
larrycavan wrote:
That is what I did. I removed the cable and filled the opening of the nut with silicone. No leaks.
1980 KZ1000 LTD
