mtc 1197 cc ring gap?
- boogy699
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- testarossa
2004 ZX-10R
Angola, IN
- bountyhunter
- Thank you received: 337
EDIT: I think that's about right.I am trying to figure out my ring gap on my total seal piston rings on an 1197cc kit. They are not the gapless rings, but are the regular ones. It says to find the clearance i multiply my bore times .0035 and I'm not sure what that means. Can anyone help?
I think my 750 twin pistons are a little over 3" diameter and nominal end gap is about .014" ballpark. Ergo, .010" should be about right for a four that totals 1200cc snce that would be same piston size as a 600cc twin (pistons a shade smaller than mine).
- boogy699
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- joehooper
Multiply 2.992 X .0035 = .010472".
This is your desired end to end clearance with the ring evenly in the bore and down 1/4" to 1/2".
Since it is unlikely that you have a feeler gauge that is .010472, I would go with .011".
- mark1122
- Keep twisting it
- Thank you received: 109
An 1197 kit has a 76mm bore or (2.992 inch), just under three inches.
X2 .
measured at the smallest point of the bore that the rings will travel, if the bore is not new.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
