kz 750 twin crankcase has some smoke comming out
- nathanhopkins
- nathanhopkins
- bountyhunter
- Thank you received: 337
- nathanhopkins
- AtLarge
- Thank you received: 21
Do you find your oil level sight glass is going up?
If you suspect gas going into the cylinders check your overflow tube. If it goes up like from the factory change the route to go down, back and over the swingarm. That might at least keep it from going into the cylinders. Then do a fuel service check to see what your float bowls are doing.
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
- nathanhopkins
- Thank you received: 2098
When you did your last oil change did the oil reek of gasoline?
To clarify ---
Overflow tubes attach to nipples from bottom of float bowls and are routed downward to exit underneath bike.
Overflow tubes aren't routed upward (because fuel doesn't flow "up.").
The float bowl vent tubes may be oem routed upward to exit underneath the seat.
Some folks prefer to route these vent tubes to exit underneath the bike (as do the overflow tubes).
