Leaking Carbs
- mooney
03 Jun 2010 22:44 #373289
by mooney
Leaking Carbs was created by mooney
Ive got an 80 kz440, my carbs have developed a leak in the fuel line where it splits into a T and goes to each carb. I took them apart and the o-rings are still there. has anyone had this problem?
- Thank you received: 2098
04 Jun 2010 02:15 #373311
by Patton
Replied by Patton on topic Leaking Carbs
mooney wrote:
Could replace the 0-rings or wrap then with teflon tape.
- moneypit
- Thank you received: 35
04 Jun 2010 13:21 #373428
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Leaking Carbs
kzrider.com/index.php?option=com_kunena&...w&catid=21&id=326051
Could give this a try I havent had an issue yet
2-76 kz900
St Paul MN
