what to do?
- b.tracy79kz
02 Jun 2010 18:12 #372926
by b.tracy79kz
what to do? was created by b.tracy79kz
i just had top end rebuilt.,new rings,valves,cam chain,ect.is there any advice on oil,or any other break in info.thanks
- timebomb33
- Thank you received: 10
02 Jun 2010 19:08 #372950
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic what to do?
i just finished a rebuild on one of my bikes i used 15-40 rottella non synthetic and 6 oz's of lucas engine break-in lube. i usally try to run the engine myself for about 500 miles then drop the oil and filter retorque the head check all the motor mounts and check and adjust valve clearances,cam chain tension and ignition timing basiclly the same thing you would do on a major tune also redo the carb sync as well.
- Thank you received: 2098
02 Jun 2010 19:21 - 02 Jun 2010 19:23 #372953
by Patton
Replied by Patton on topic what to do?
And for the first 500 miles, don't baby it, and avoid long periods of single continuous speed. Helps the rings seat.
After the first full overnight cool down, with engine cold, and before engine is cranked, would consider re-torquing the head. Doesn't hurt to repeat this cold head re-torque procedure more than once.
Last edit: 02 Jun 2010 19:23 by Patton.
- 550A2
- keep the shiny side up
02 Jun 2010 19:31 #372957
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic what to do?
i would like to add, downshift at a little higher rpm's to stop signs and lights instead of coasting, that usually helps to seat the rings.
