KZ1100 Pistons carbon removal.
- kz1100warrior
02 Jun 2010 01:50
Hi all , please can someone help me, I have a 1981 kz1100 A1 Shafty.
I had to remove my barrel due to oil leak from base gasket. When taking the barrel off i noticed that my piston heads were very built up with carbon. Now my question how much carbon should be on the top of the piston.
My spark plugs are very black and sooty, not wet dry....no 3 spark plug was the only one that was correct burning light brownish...but no 3 piston had the most carbon on.Is this correct.
Aslo what is the best way to clean the pistons of csrbon.
Thank you very much.
Travis
South Africa.
Travis
South Africa.
- BSKZ650
Re: KZ1100 Pistons carbon removal.
02 Jun 2010 05:44
since you have the bike down, have you checked the cyls for size to make sure they are still in spec?
at this point assuming they are still in spec I would hine the cyls and replace the rings and valve seals. as far as cleaning the carbon, carb cleaner and a wire brush works well, just make sure to stay away from the ring lands, exept for carb cleaner to remove carbon from them
77 ltd1000, current rider
76 kz900, just waiting
- bountyhunter
02 Jun 2010 11:45 - 02 Jun 2010 11:45
Acetone (non chlorinated brake cleaner spray) and a toothbrush. Scotchbrite pad for the stubborn stuff.
Last edit: 02 Jun 2010 11:45 by bountyhunter.
- APE Jay
02 Jun 2010 15:05
3 or 4 hours in full strength Simple Green. However, the more carbon on the top of the piston, the higher the compression ratio. Remove the carbon, loose a little power.
If you were running in a race class that had a spec piston, it never said how much carbon you were allowed, but the racers never removed it.
- TeK9iNe
- What did you do!?!
02 Jun 2010 15:09
APE Jay wrote:
I whole heartedly agree!
There was no spec for head/base gasket thickness back when too...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- muddy1
- 1980 Kz1000 LTD B4
02 Jun 2010 16:24
most of those bikes that had enough carbon buildup on them to increase performance did not last long (according to Evil Jimmy)my 4 stroke mentor LOL
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- MDawnz1
09 Jun 2010 01:40
And we used to bake on three coats of VHT to the piston tops.
It built up a great layer of carbon evenly on all the pistons. FAST !
Hay, the rulebook didn't say we couldn't.
It just came down to keep your mouth shut and let the machine speak.
1974 Z1a, still 903
