1977 kz650 oil change question
- kz.chris
01 Jun 2010 11:28
Do I need to remove the fuel tank to get to the oil filter?
If so, is the tank hinged or do i need to remove it completely?
Thanks,
Chris
Thanks,
Chris
1977 Kawasaki KZ650
- Bluemeanie
Re: 1977 kz650 oil change question
01 Jun 2010 12:43
Is this a trick question?
Your oil drain plug and oil filter are down under the bike on the oil pan. Place bike on center stand for this entire operation. Front plug is oil drain, drain that first. Re-install plug snugly. (aluminum strips easy, careful) Rear plug holds oil filter cover (about 4" or so in diameter) loosen this plug and then spin off slowly (more oil will come out) entire cover. Pull old oil filter off and replace "O" rings (If included with filter) Install new filter with spring under filter and basket under spring. Lightly coat "O" rings with oil and re-install cover and snug up. Add three quarts oil of your choice. Oil fill is on right side (sitting on bike) on top of clutch cover. Make sure to re-install oil fill cover before starting bike other wise oil will fly everywhere! Shut bike off and recheck level, you will add about another 1/2 quart or so to upper fill line. This level window is down below on clutch cover. And that's it!
- kz.chris
01 Jun 2010 14:51
Thanks a lot!
I guess that would be the air filter under the gas tank then :blush: . How do I get to that? I can get to half of it under the seat but the fuel tank is in way if i want to remove the filter completely.
Thanks!
Thanks!
1977 Kawasaki KZ650
- anarki650
01 Jun 2010 15:14
All you have to do is open the seat on the hinges and lift the rear of the fuel tank to get the air filter cover off. No need to unhook the petcock or lift the tank completely.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
01 Jun 2010 15:39
In addition to the tons of information around here, a factory shop manual is invaluable.
- Old Man Rock
02 Jun 2010 04:00
As Texas just pointed out... You need this!
KZ650 OEM Manual, free download, bottom right...
jarlef.no/Kawasaki/Series/Z/650/z650files.htm
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kz.chris
02 Jun 2010 07:46
great info! thanks much!
1977 Kawasaki KZ650
- tinlizzie37
02 Jun 2010 14:39
Hi KZ Chris, If you're interested in a manual, I have a good used Kaw Factory or a brand new Clymer. Either one for$20. plus shipping. Bob
Bob KZ 650 E1, En 450
- Kawickrice
02 Jun 2010 15:05
If you are mistaking the canister looking thing on the top of the motor under the carbs for an oil filter this would be incorrect. As stated earlier the oil filter is under the motor. The canister looking thing is a breather for the crankcase. Hope this helps.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
